Question about Sewing Machines
Janome JD1818 Automatic Buttonhole Not Working
I've used my automatic buttonhole feature before, but now it won't work. I've checked my manual and I appear to be doing everything right, but all that happens when I go to start a buttonhole is the initial beginning ziz-zag. It just continues to do this and won't move onto the next step.
  • 3 more comments
  • Aurora199
    Aurora199 Mar 16, 2008
    I am now trying to just do normal sewing and my feed dogs will not advance my fabric. The feed dogs are in the up position, but just move up and down without advancing the fabric. When I press the reverse button it moves the fabic backwards like normal. Stitch length makes no difference and I just cleaned the feed dogs.
  • Aurora199
    Thank you for your response. Unfortunately the problem seems to be caused by the feed dogs, since they are no longer operating properly (mentioned in my second post). Any ideas for fixing/adjusting feed dogs?
  • caroline1 Apr 17, 2008
    my janome buttonhole foot just dose the first step of a buttonhole then wont go on to do the rest
  • hebandgene Jun 19, 2008
    similar problem here. it sews the front and left side but just bunches up when it gets to the back. i have been able to get it to function successfully hit or miss but there seems to be no consistency or user error.
  • cstabler Aug 17, 2008
    I'm having the same problem. It used to work, but now the buttonhole foot just does the first step of a buttonhole then wont go on to the next step.
If everything appears to be working correctly for the first side and stops and bunches up when it should reverse - Make sure you have pulled down the stopper arm (this is not clear in the manual) when the button hole foot contacts the stopper arm gently push the foot against the stopper arm and the direction will reverse and finish the button hole. **Stopper arm pulls down from above - Check the pictures in you manual carefully.**
Posted on Sep 11, 2008
I couldn't work out why mine stopped working.... .and it was because I had forgotten that I had switched the feed dogs off ('round the back) when I sewed on a button. Once the feed dogs were back in action, it worked a charm.
Posted on Jul 25, 2008
  • Sewing Machines Master
  • 1,388 Answers
If you know that your reverse mechanism is functioning normally for ordinary sewing, and not at fault....
Make absolutely certain the position of the sample button in the holder is correct, and the button hole foot assembly is attached with the stopper in the correct position, as the stopper arm must engage to "tell" the mechanism to stop and change direction.
If you cannot see from the manual quite how this is achieved and you want more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Is it possible to override the automatic buttonhole setting on a Necchi ex30?
Are you asking if you can do a buttonhole without the special buttonhole feature? If so--of course you can. Sewists do it all the time on machines without the buttonhole feature or special feet. Be sure to practice on some scrap fabric first.
Until Wednesday Calls How To Manual Machine Buttonholes
Feb 25, 2016 | Necchi Sewing Machines
I can not get the automatic button hole to work properly on my Janome 6019.
Hello what is the machine doing
for example i have a 5018 with mine there is a lever at the back to pull down which when it finishes half it stops and resets itself to complete the other side and stops when complete but need the button in the compartment to guide for sizing
i will do a video clip on my channel send more info to mysteria21@gmail.com
Feb 25, 2015 | Janome Sewing Machines
My automatic buttonhole stitch is not working on my elna sewing machine ,even when the lever is pulled down
you should a buttonhole button that must be pushed on the machine
either before you pull the buttonhole lever down or after to let the
sewing machine know what function to use, my sewing machine
won't let me make a buttonhole unless I push the buttonhole button
or yes, like you said the buttonhole foot could be damaged.
Nov 09, 2012 | Elna Sewing Machines
Cant get my janome excel mw 3018 to do an automatic buttonhole
I would suggest taking the machine back to where you bought it & letting them show you how to make a buttonhole or getting another
machine
Aug 21, 2012 | Janome Sewing Machines
My buttonhole is not working I hear a beep when i press down on the foot to go, what am I doing wrong
I get the same beeping when I forget to pull down the buttonhole lever
if you have the automatic buttonhole & the buttonhole foot that you have to put a button in,,check & see if there is a buttonhole lever that has to be pulled down, it will be a lever to the left of the needle bar
Aug 07, 2011 | Singer 7436 - INGENUITY
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
I keep getting the bl sound when trying to make automatic button
I'd forgotten to pull the little lever down that abuts onto the buttonhole foot! Simple!
Nov 28, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
1,149 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
