Question about Garmin nuvi 350 GPS Receiver
GARMIN 350 can not acquire satelite signal? i tried reset but that did not help.
  • 7 more comments
  • GARMIN 350 Apr 06, 2008
    this solution did not fix the problem
    i have tried this already still did not work
    i did the update still did not work.
    still nor working
    can not aquire satelite,reset,updated,delete errors nothing seems to work. does any one have any other idea?
    i have tried this did not work. when i close the antenna the device gets satelite very weird and when i open the antenna the satelite signal get lost.
    when the antenna is open it can't get any satelite signal. when i close the antenna it does get a satelite signal when the antenna is close. but when i open then antenna again it loses the satelite signal. can someone tell what this problem could be.
    i think the problem is the map software that was pre downloaded with the unit when i bought it is no longer updated. do you guys have a software updated version for my nuvi 350 for me to download this may fix the problem.
  • GARMIN 350 Apr 07, 2008
    i have tried everything nothing seems to work, do you guys have other suggestions?
  • 3,037 Answers
Seems to be an issue with the antenna connection inside. Either a short or bad connection. Try to get it working by tapping the unit which may get something connected again. Other people have had this same problem. The device is just defective and if you can replace it, they may even replace it if the warranty is done. Let me know if anything happens with some small taps and whether you want me to give you other things to try or if you are just going to try and replace it but my bet is that the antenna connection has a problem.
Thank you and good luck
Posted on Apr 06, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 06, 2008
    the antenna sounds defective because when you are opening it, whatever the metal on the antenna is supposed to touch, it isn't touching. If the signal is as strong as it can be when closed, then that is good, but it is acting weird. Easiest fix would be to replace antenna and see if the new one works otherwise there is probably a loose piece of metal somewhere in the device which will need to be resoldered.
    Please let me know if you have any further questions, thank you
  • Benjamin Patri
    If you want to try a software update, then go here
    http://www8.garmin.com/support/download_...
    and you can try fixing it by downloading new software
  • Benjamin Patri
    Benjamin Patri Apr 07, 2008
    you have actually opened the device and checked around the antenna for a bad connection?
    Master:
    Sergeant:
  • 462 Answers
Keep the device without power for 10 min then before supplying power press the power button ON for 10 sec, then again leave it ideal for 10 min. Repeat this for 2 times and then resume ur operation.
Thankyou
  • 1 more comment
  • Mohamed Ismail
    Mohamed Ismail Apr 06, 2008
    Thank you for your response, we will look into this and let you know soon.
  • Mohamed Ismail
    Following is the update for your GPS, i request you to update and give it a try.
    http://www8.garmin.com/software/nuvi350_...
    Thankyou
  • Mohamed Ismail
    The unit is appeared to have "stuck" in this acquiring mode, following is the instructions :
    1) open the GPS antenna
    2) press the bottom left screen while holding the power button to turn the unit on
    3) enter maintenace mode
    4) select diagnostics
    5) clear error report, do NOT clear any user data
    6) restart unit the usual way
  • 796 Answers
Have you checked whether all the connections are plugged in properly
there may be some misconnections
  • isaac johny
    isaac johny Apr 06, 2008
    Garmin's FAQs.
    If the GPS is having issues acquiring satellites
    on the dash of the vehicle, the problem most likely is due to the
    coating that the manufacturer applied to the windshield. Some cars are
    equipped with special windshields that may contain metal in the glass
    (metal oxide) that prevents the gps from having a clear line of site to
    the satellites.
    Windshields with solar ray glass, solar tint,
    heated or heat reflective windshields, and insulated or Insta-Clear
    glass may also affect satellite acquisition. If the car has one of
    these windshields, an external antenna might be required to receive
    satellite signals. If unsure about whether the vehicle has one these
    mentioned features, contact the dealer.
    The other thing you can
    try is to close and reopen the antenna. Sometimes that wakes up the
    unit, especially if it was turned on when out of satellite site.
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
Acquiring satellites
The problem might be that your GPS is not able to connect to the satellite.
I'll see what the problem might be.
Mar 15, 2008 | Garmin nuvi 350 GPS Receiver
GPS Firmware Upgrade Popup
Easy problem to repair. Please see this link for repair assistance.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
May 28, 2010 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 610 - Acquiring Satelites
My Nuvi 255w was doing thew same thing. I called Garmin and was told to send it back for replacement or repair. I can only suggest to you at this time to cxontact Garmin customer service
www.garmin.com
Aug 11, 2009 | Garmin GPS
Garmin nuvi 350 satelite lost
Try flipping the back part up.
Jun 20, 2008 | Garmin nuvi 350 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
20 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
