Question about Pentax Optio S5z Digital Camera
Unlock Pentax Optio S5z
My Pentax Optio S5z locks itself somehow. Before it usually unlocked on it's own also. Now it is stuck on LOCK and I am not able to delete pictures, or use the MENU or MODE buttons. I am able to take pictures however. How do I Lock/UNLOCK this camera?????
  • 2 more comments
  • bsho May 07, 2008
    I bought my s5z used, and the lock just shows a yellow padlock picture when I try to access the menu or other functions. I can just take pictures. How do I change that (unlocking it)?
  • Anonymous Aug 01, 2008
    I have suffered the same auto-lock problem as described in 'RoseAleta's Unlock Pentax Optio S5z problem' and eventually unlocked it by randomly pressing every conceivable button combination. Will try your suggestion first if it happens again.
    Please notify me if a more permanent solution is found
    ian@beswick.co.za
  • Anonymous Feb 28, 2009
    Thank you so much! This worked for me too. Being a little tech-illiterate it took a while for me to find the reset option (kept on going down the recording menu, rather than across to the setup menu!) but I got there in the end.
  • Anonymous May 18, 2009
    MY OPTIO S5Z HAS BEEN LOCKED WITH THIS SOLUTION IT HAS BEEN OPENED
    THANKS BUDDY, IT HAS SOLVED MY PROBLEM THANKS & LOT
I had the same problem with the exact same camera (Pentax Optio S5Z) that happened the same way. I searched everywhere on the web and finally found this post that didn't have a solid solution. So I started experimenting with different button combinations and finally figured it out.
Hold the OK button while turning on the camera. The screen should indicate that it is in audio record mode. Now press the Menu button and use the navigation keys to find and execute the system reset option.
After turning it off and back on it should function normally.
Posted on May 07, 2008
  • paulclark123 Oct 11, 2010
    For the Pentax Optio W 60 press MODE > TRASH > OK. That worked for me.
  • reynoldsjoan Nov 02, 2010
    That worked for me to on the Pentax Optio W10. Thankss
Hello
i did have the same issue and i did the exact solution (bsho solution N#2 ) but when hold OK when opening the cam i have the same issue all keys do the same function
can not access to the menu i can only start recording voice
can any one help me out here :(
Posted on Feb 19, 2010
Solution #2 worked perfectly! Follow BSHO's solution to the letter. It works! Thanks, man!
Turner
Posted on Dec 16, 2009
Thank you sooo much *bsho* I had this exact same problem on my camera for about 3 weeks ,and it was really making my angry!.. Thank you so much for your solution it worked for me!
Posted on Sep 19, 2008
Does anyone know, how to UNLOCK that thing, please? Thank you, regards, Karl from OZ
Posted on Sep 14, 2009
2 Suggested Answers
  • 11967 Answers
SOURCE: My Pentax Optio S5z locks itself somehow. Before
Is the slide switch on the side of the card in the unlocked position? If so, try this...remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Posted on Dec 28, 2009
Card unlock pentax optio
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 10, 2013 | Aqua Pentax Optio S12 Digital Camera
Card locked
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 03, 2012 | Pentax Optio S5z Digital Camera
I have a pentax optio e50 , when i turn it on says that card is locked , yet the card inserted is on unluck i cant not take any pictures.
These cards usually have little tabs on them to "lock" and "unlock" them. Try moving the switch and see if that works. If not, you can also try using the card on another camera or a computer (through a card reader) to see if that works.
Feb 28, 2011 | Pentax Optio E50 Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
My Pentax Optio S5z locks itself somehow. Before it usually unlocked on it's own also. Now it is stuck on LOCK and I am not able to delete pictures, or use the MENU or MODE buttons. I am able to take...
Dec 28, 2009 | Pentax Optio S5z Digital Camera
How do I unlock the memory card?
Move the slide switch on the side of the card.
Nov 11, 2009 | Pentax Optio S6 Digital Camera
Instruction manual for pentax optio s5z
I could send you a copy of the manual on CD.
Where do you live?
May 10, 2009 | Pentax Optio S5z Digital Camera
My Pentax Optio s5Z is stuck on one mode
I also had this problem. I think it is caused when the camera is turned off while in the viewing part of the camera. That is, I had gone to look at the video that I had just taken, but didn't and then turned the camera off. The camera is then as you have described it.
The only way I could get it back to normal is to connect the camera to the computer, using the cable, and download the photos and videos. When the download is complete, disconnect the camera and it should be OK.
Good luck, cheers. Phil
Sep 09, 2007 | Pentax Optio S5z Digital Camera
Pentax Optio S5z Digital Camera Logo
2,073 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
