1999 Audi A6 Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the starter on a audi a4 1997 - 1999 Audi A6
ZJ Limited
Level 3:
  • Audi Master 17,989 Answers
  • Posted on Apr 05, 2010
ZJ Limited
Audi Master
Level 3:
Answers
17989
Questions
0
Helped
14458372
Points
60858
REMOVAL & INSTALLATION
where is the starter on a audi a4 1997 - 0900c152800c2aae.jpg Fig. After the negative battery cable is disconnected, remove the wire terminals from the starter solenoid
0900c152800c2aaf.jpg Fig. Remove the lower starter mounting bolts... 0900c152800c2ab0.jpg Fig. ...followed by the upper bolt, then remove the swhere is the starter on a audi a4 1997 - 0900c152800c2ab1.jpgansaxle housing
0900c152800c2ab1.jpgFig. Lower starter bolt locations-1994 2.0L, 2.0L ABA
0900c152800c2ab2.jpg Fig. Remove the upper starter bolts
where is the starter on a audi a4 1997 - 0900c152800c2ab4.jpg/images/0900c152800c2ab3.jpg" alt="0900c152800c2ab3.jpg" class="h_mi" /> Fig. Mark the lwhere is the starter on a audi a4 1997 - 0900c152800c2ab5.jpgf each starter bolt
0900c152800c2where is the starter on a audi a4 1997 - 0900c152800c2ab6.jpg Fig. Remove the starter
0900c152800c2ab5.jpg Fig. Close up view of the starter drive gear
0900c152800c2ab6.jpg Fig. When the solenoid is energized the starter drive is pushed out and meshes with the flywheel to crank the engine
  1. Note the radio security code, and then disconnect the battery ground cable.
  2. Raise and safely support the front of the vehicle with jackstands.
  3. If installed, remove the lower engine shield.
NOTE The engine must be supported on 1990-97 Passat models as the starter mounting bolts also support the engine-to-transmission mounting surface.
  1. If necessary, label the small wires before disconnecting them.
  2. On 1990-97 Passat models:
  3. On Audi A4 and 1998-00 Passat models:
    1. Release the number 50 electrical connector from the starter.
    2. Then remove the nut for the large battery cable and remove the cable.
    3. Loosen then remove the clamp that secures the heat shield to the starter.
    4. Remove the fasteners securing the bracket at the front of the starter and remove the bracket.
  4. Remove the starter mounting bolts, while supporting the weight of the starter.
  5. Pull the starter straight out from the transaxle.
To install:
NOTE On vehicles with a manual transaxle, there is a bushing where the starter shaft fits into the bell housing. If the shaft or bushing is worn or if the starter has been jamming, the bushing should be replaced. There is a special bushing removal tool available but a small inside bearing removal tool is usually sufficient.
  1. Install the starter into the transaxle.
  2. Tighten the related starter motor fasteners as follows:
  3. Starter support bracket, M5 nut: 35 inch lbs. (4 Nm)
  4. Starter support bracket, M8: 16 ft. lbs. (22Nm)
  5. Battery cable to solenoid, M8 nut:10 ft. lbs. (13Nm)
  6. hydraulic hose support bracket, M8: 84 inch lbs. (10Nm)
  7. Starter mounting fasteners, M10: 44 ft. lbs. (60 Nm)
  8. Starter mounting fasteners, M12: 48 ft. lbs. (65 Nm)
  9. The balance of the installation is in reverse order of removal.
NOTE Be careful not to over tighten the battery cable connection. The metal is soft and the threads will strip easily.
  1. Lower the vehicle from the jackstands.
  2. Connect the negative battery cable and enter the radio security code.
Starter relay location 2005 audi a6 quattro
On the 2.8 the starter is located passenger side (underneath), a little back of the Alternator. https://www.audiforums.com/forum/audi-a6-9/changing-starter-c5-4-2-a-178506
The Audi forums is a great place for information, And good luck you'll need it
tip
Where is the starter motor located on audi 100 2.8?
The starter is located at the rear bottom of the engine, the nose of the starter goes into the transmission bell housing, you must access the starter from under the car.
Where I can find Audi TT 2002 starter relay? what name it is and where it is located? thx, Henri
hi starter relay of Audi TT 2002 its located under the carpet where the passenger beside driver all the relay is there
Starter removal 1990 audi quattro v8
1990 Audi V-8 Quattro 3.6L DOHC
Starter, removing and installing
Disconnect battery NEGATIVE cable
Disconnect wiring from battery to starter and starter to alternator (large terminal)
Disconnect terminal 50 (small wire to ignition/starter switch)
Remove starter mounting screws on engine/transmission
NOTE: Remove upper bolt on starter by guiding 10 mm Allen socket with extension and flex fitting through opening on transmission housing over final drive
Remove starter motor assembly
Reverse procedure to install
2helpful
Hi, where is a starter located in my audi A4 1998 1.8?
The starter location in Audi A4 1998 1.8 is on the right middle-bottom back side of the engine. Removing & installing instructions:
2helpful
Where is the starter motor on my audi 100 2.8
the starter is located at the rear bottom of the engine, the nose of the starter goes into the transmission bell housing, you must access the starter from under the car.
97 audi a4 no power/battery fuse?
Sounds like either the battery leads are on the wrong way round, or the starter main cable is touching something and shorting to earth. Retrace your steps and check your connection locations.
Either that or its a dead short through the starter. Remove main cable from back of starter and tape up incase of short. then reconnect battery. If ok now then your looking at starter motor.
TL
4answers
Starter is turnig but not firing
Starter switch. Plastic and cheap, my 98 A6 did the same thing... I replaced thousands in parts, turned out to be a cracked ignition switch which is a very common Audi problem!
1985 Audi 5000 won't start.
Replace the starter. The starter drive which is called a Bendix on the end of the starter is broken.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
