Question about Creative Labs Zen V MP3 Player
Stuck in recovery mode, never been used, screen states firmware problem . everything i have tried has not worked. Tried cleaning mode, reload firmware mode, noting. HELP
  • dragonfly55 Mar 16, 2008
    it is actually a creative zen 4gb
    President:
  • 4,402 Answers
Stuck in recovery mode Zen v
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
SOURCE:
What can i do if stuck with recovery mode ? i had done reboot , format , clean up and reload firmware but it doesnt worked at all . does it cannot be fix anymore ?
what can i do if stuck with recovery mode ? i had done reboot , format , clean up and reload firmware but it doesnt worked at all . does it cannot be fix anymore ?
Jul 08, 2012 | Creative Labs Zen Micro MP3 Player
Credit card size zen
Hi Lil
Sounds like you have tried all the obvious. The unit may have a terminal hardware problem or an unrecoverable firmware problem. I suggest that you return the unit to a dealer and see if there support guys can produce a cure for you. I am looking for any other things that you may try. Will post any for you soon
regards
Graeme
Feb 17, 2008 | Creative Labs Zen Digital Media Player
Recovery Tool not working
format player then use recovery tool you have a corrupted file that keeps affecting the rebuild.
Sep 05, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative zen micro stuck in recovery mode
To Fix any problems with broken firmware form attempted “playsforsure”
firmware updates etc where your pc finds it as a 20mb drive and it sits
in recovery mode and does bugger all:
1. Uninstall all creative software & drivers
2. Uninstall Media Player 11 and Media Player 11 runtime (will require a
reboot for each thing). This is done by going to add/remove programs and
uninstalling (this will put your pc back to wmp10).
3. Re-install the Zen Driver from the creative website and reboot (I just reloaded Media Explorer using my ZMP install CD).
4, Plug Zen in.
5, Make sure you have the firmware update ready, run it but don’t click
the language bit yet), leave the mouse hovering over your language
selection. (for ZMP, just start firmware exe file, there is no language selection. You can get the firmware update from Creative’s site, go to SUPPORT and then DOWNLOADS).
6. On the Zen- select “reload OS” (on ZMP I believe it is Erase or Reload Firmware, something like that, don’t have it in front of me).
7. As soon as it flashes up “reload new firmware now via USB” click the
language button
8. Now the pc should find it and allow you to re-load the
firmware. (it may take a few attempts)
9. Once complete, click close and restart the pc. Everything should now
be fine.
10. Once all is working, you can re-install WMP11 and it will work fine.
Dec 28, 2008 | Creative Labs Zen Touch MP3 Player
Stuck in recovery mode and firmware problems
My Creative Zen mp3 player is stuck on Recovery mode , and keeps on saying filmware problem. I have tried to reset, push power button down and push play button at the same time. I also tried Clean-Up Format and reload filmware.
Nothing has worked, and I am about to throw it out the window.
Please if you can help me.
Thank You
Oct 15, 2008 | Toshiba Gigabeat S30 MP3 Player
Stuck in recovery mode--would love to avoid buying a new mp3
I had the same problem as your and it stopped working yesterday. After search for helps and now it is working again after I reloaded the firmware. But unfortunately everything is gone. You have to reload your musics again. You can try this out: 1) go to creative labs website to download the "Recovery Tool". 2) at Recovery Mode of your zen there are options: Clean Up, Format All, Reload Firmware, and Reboot. Try out Clean Up first if it still not working then try to Format All. After that try the Reload Firmware. After you done the Reload Firmware. 3) Shut down your Zen and try to connect it to your computer. Now your Zen will automaticlly power On and computer will recognize it as a drive. 4) Open the Recovery Tool you have downloaded at creative labs website. This tool will detect your Zen and follow it's instructions: It works with my windows Vista. Well, it works for me, I think it will work for your too. Good Luck!
May God bless.
Jul 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Recovery Mode
I agree, use the Reload Firmware tool on recovery mode and then upgrade the firmware from the website. If you get "firmware failed!", then try it from a different computer.
May 08, 2008 | Creative Labs Zen Digital Media Player
Stuck in recovery
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Apr 09, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Micro
Sounds like the hard drive is bad, was the unit dropped?
Dec 01, 2007 | Creative Labs Zen Micro MP3 Player
Randomly Went to Recovery Mode
The hard drive is bad and you will need to get it replaced. There is a repair service box on this page if you scroll down; just enter your zip code to find a repair service near you.
Aug 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen V MP3 Player Logo
273 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
