Question about Kenmore 60721 Refrigerator
Kenmor frig not getting cold
I have a sears kenmore frezzerless refrigerator (model 60722), approx 2 years old - It is not cold inside, although walls feel cold, fan is running but not blowing cold air, light is not on when door closed, seal is good. Compresser is running coils and seem to be cold. any suggestions
  • 2 more comments
  • Anonymous Jun 11, 2008
    my refrigerator is not blowing out cold air.
  • gdwiseman Jan 02, 2009
    Kenmore fridge just suddenly stopped cooling, although the compressor is working, according the Sears repairman, who is out of ideas. It's less than 2 years old.
  • Durhamite Apr 08, 2009
    Same model 60722, the fridge goes down to about 49 degrees but can't get any colder. Door seals seem fine. It's running all the time. There's a couple of very similar problems posted on the Sears site and they talk about refrigerant leaking and nothing can be done to fix.
  • LOREN May 14, 2013
    COMPREESSOR IS REALY HOT
Same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Posted on Aug 12, 2008
SOURCE:
How can I reset the alert reset on my kenmor elit refridgerator
What is the model number for your Elite? Model number looks like 106.1234578 as example found inside the fresh food compartment on the wall inside or around the fresh food section door.
APPLIANCE 911
Apr 15, 2016 | Kenmore Refrigerators
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kennmore is freezing everything in the fridge side and it is turned down to 0
YOU HAVE A BAD FRIG. THERMOSTAT REPLACE IT,GO TO SEARS .COM CLICK ON PARTS ,PUT IN YOUR MODEL NUMBER(ON INSIDE OF FRIG. OR FREEZER WALL) AND YOU CAN GET THE PART YOU NEED,LET ME KNOW HOW YOU DO-MIKE
Oct 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Oct 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer not getting cold enough
I think your system has a leak and has lost the refrigerant charge.
The only way to check is by accessing the sealed system. Most systems are covered for five years on the compressor. Contact the place of purchase and give them your indications for your problem.
Jul 06, 2008 | Freezers
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Nov 26, 2007 | Refrigerators
Kenmore 60721 Refrigerator Logo
559 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
