Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
No Picture no sound
My DLP made a weird noise and the picture and sound went out. I replaced the lamp and there is still not picture or sound. What do you suggest.
  • 59 Answers
The color wheel will make a high pitched sound or even a clicking sound if it is bad. Also the ballast will make a clicking sound also if it is not seated to the lamp properly or if the ballast need replaced.
Posted on Mar 23, 2008
SOURCE:
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
Why would a Mitsubishi WD-65735 Television turn on and have sound but no picture?
have you pulled the lamp out & checked it. It is possible you have gotten poor quality lamp. It is critical on a mitsubishi to get the proper lamp.
Lamp-Cartridge 915B403001
http://www.shopjimmy.com/mitsubishi-915b403001-dlp-replacement-lamp.htm
May 08, 2014 | Televison & Video
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
We have a samsung DLP tv model number HLP 4663W tv. The picture went so we replaced the bulb. Still no picture and the tv makes a noise that sounds like a fan and the tv cycles on and off by itself. ...
Yes, almost certainly a bad color wheel, see attached photo.
If you remove the lamp and look in the direction it faces you should be able to see the wheel, look for it to be missing pieces or shattered.
You Tube has detailed video instructions for replacement in most of the Samsung sets; I have replaced dozens of the wheels.
Before you rate my solution let me know if you have any questions by commenting here.
SD TECH
Jul 08, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP making noise and is picture out
Lamp probably went out. Refer to your manual regarding lamp replacement.
May 16, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLR4667 DLP picture problems
Color wheel problem. replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 03, 2017 | Samsung DLP HL-P5663W 56" TV
Loud cracking sound, and now, nothing
Hopefully its only the lamp. Inspect lamp for breakage. Lamp power supply ok??. Check any air vents (filters if any) before replacing. Lamp life is only a few thousand hours, easy to do in a year, 5-6hrs a day. Check your manual.
Oct 29, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
166 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
