Question about Braun 4501 Electric Shaver
Braun 150 shaver
How do I disassemble the braun 150 shaver to replace the circuit board and battery?
Thanks for your attention and help.
Alex Trost
SOURCE:
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
Cytherian
  • 124 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Posted on Oct 22, 2009
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
brector3
  • 1639 Answers
SOURCE: I have a Braun model 7526 shaver and the batteries
You will need to first remove the 'cap' on the bottom of the shaver. This is a piece of plastic that surround the hole on the bottom of the shaver where the cord plugs in. Gently pry it off with a small flat screwdriver or similar object. Once removed, the side grips will simply pull off revealing 4 screws on the back. Remove screws to remove the back cover.
From there it is a piece of cake. The internal components simply lift out.
Put it back together in reverse order
Posted on Jan 20, 2010
brector3
  • 1639 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
How do you replace a battery on a Braun 7680 Shaver?
I replace my Bruan 7680 battery. I place the order for battery from Amazon, cutter& foil from goodmans.net. The following is my procedure 1.Using a small flat screw driver to plier the plastic socket lock (Where the charging located ) 2.Disassemble left and right plastic holder 3.Disassemble plastic cover top and bottom 4.Take out the circuit board where the battery mounted on. Please be careful at this process you could ruin the circuit board while taking the old battery out(I used a soldering and a small wood stick just to take the extra flux away from contact to other on the circuit board).It is not as difficult as I thought. 5.During your install a new battery please make sure that the batter pole does not go the same way(Check direction of a battery before taking it out so you do not put in the wrong direction) 6.Putting them back together. Note #special tool required to take out the circuit board from a mounting?My the battery replacement came with the tool)
Apr 19, 2011 | Braun Activator 8595 Electric Shaver
Braun 7526 needs new rechargable battery
You will find batteries for model 7526 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for disassembly video instructions.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 21, 2011 | Braun Syncro 7526 Electric Shaver
How do I change the battery?
You will find a disassembly video at shaveroutlet.com. See link below and scroll down for video
Feb 21, 2011 | Braun Syncro 7570 Electric Shaver
My Braun electric shaver model 7680 has stopped functioning probably due to a dead battery ( I had it for years). A service center is asking in excess of 60 dollars to fix it. Battery and mother board...
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at shaveroutlet.com. You can order which you require. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-circuit-board-with-batteries-select-models-p-772.html
There is a tip on the battery page for easier installation
shaveroutlet.com has an instructional video that shows you how to disassemble the shaver at the link below. It's the 4th video down
http://shaveroutlet.com/video_tutorials
Oct 14, 2010 | Braun Syncro 7680 Electric Shaver
I need a replacement battery for my BRAUN 8585 shaver. When (if) I manage to lacate a battery I will need instructions on how to replace the battery.
You will find compatible battery type at shaveroutlet.com. See link below. Be sure to read the NOTE on the page concerning installation
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
If you are not able to solder in new batteries, you may want to simply buy the circuit board that includes the batteries. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
To disassemble the shaver, first remove the 'cap' on the bottom that surrounds the hole where the cord plugs in by gently prying it off with the tip of a small flat screwdriver or similar object. Once removed, the side grips simply pull off revealing 4 screws on the back. Remove the 4 screws to remove the back cover and access the insides. Reassemble in reverse order.
Aug 20, 2010 | Braun 8585 Electric Shaver
Braun 5750 needs new battery -this i think is only available with circuit board - where can i purchase or get this shaver repaired
If you are handy and know how to solder (and have the tools required), you can probably do the replacement yourself.
At the bottom of the razor are two plastic caps on either side of the charging port, you'll need to pry them out with a sharp pick or thin knive tip. Once removed, you can get to the screws that hold the front and rear case halfs onto the main shaver chassis where the PCB with the rechargeable battery is soldered onto the board.
Unsolder the battery and solder in the new replacement battery and put the case back together, making sure all the parts are in the correct posistion, and you're ready to recharge the shaver and start shaving again. If you're going to replace the internal board, it's just a matter of simply replacing the entire board and orienting the motor assembly connection onto the new PCB.
To find your replacement parts or batteries, try Electric Shaver Service. They also do repairs, so you might want to get an estimate if you don't want to do the repair yourself, etc. They're reliable and fast in getting shavers repaired and back to you quickly. 1-888-476-1785
Here's a link to the page with your battery on it and the toll free number to call for estimates too.
www.electricshaver.com
Hope you find this Very Helpful and best regards!
Oct 12, 2009 | Braun Health & Beauty
Braun electric shaver will not charge.
Your batteries are no longer capable of being recharged and need to be replaced.
If you are handy and can dissemble and solder, you can do this yourself, otherwise, you can send it off to a repair service that will do this for you.
If you wish to do this yourself, you'll have to take the shaver apart. There are two (2) small plastic caps on the bottom of the shaver that can be removed with a small pick or flatbladed screwdriver. Once those are out, you can unscrew the two screws that hold the shaver together and gently pry off the side panels.
This will expose the internal circuit board and the rechargable batteries that need to be unsolded. You can then reinstall NEW rechargable batteries and solder them onto the PCB (printed circuit board). You can also purchase a complete internal PCB with the batteries and everything you need, you just swap out the electronics for the new one, although this costs about $39, while the batteries alone are much less.
Put the shell together and reinstall the retaining screws and caps and you're done.
Here's a link to get the replacement batteries for your shaver. They also do the repair service, if you don't want to do it yourself.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Sep 05, 2009 | Braun Flex Integral Shaver 5520
I just need to know where I can get new batteries for my braun syncro 7505. The batteries don't have any markings telling the volts or milliamps. I would greatly appreciate it if someone could help me with...
Yes, these are NiMH AA 1.2V flat top batteries. Replacements can be found on some battery websites (like onlybatteries.com). I'd get the 2200mAh rated ones, as they'll hold a longer charge than the 1650mAh ones. You will need two of them (the shaver has a 2.4V motor). This works for most Braun shaver models from 6000 to 8000.
Aug 15, 2009 | Braun Syncro 7526 Electric Shaver
Need to replace 5569 rechargeable batteries
To find your replacement battery, try Electric Shaver Service. They also do repairs, so you might want to get an estimate if you don't want to do the repair yourself, etc. They're reliable and fast in getting shavers repaired and back to you quickly. 1-888-476-1785
http://www.electricshaverstore.com/search.asp?p=2&w=%5F&c=battery&t=s&m=0
Jul 29, 2009 | Braun 4501 Electric Shaver
Braun 4501 Electric Shaver Logo
107 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
T.Johns
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
