Question about RCA RCR860 Remote Control
Accidentially dropped something on remote.
I dropped something on my remote, well laid my laptop down on it, and im assuming some buttons were pressed down. now my tv is locked, the only button that is working is the power button. what do i do?
  • 979 Answers
Replace the batteries for starts. If the remote was having any buttons pressed for a long period of time, the power capacity of those batteries is quite diminished...accordianman
Posted on Mar 16, 2008
6ya staff
SOURCE:
How can I disable closed captioning?
Closed captioning frequently is enabled/disabled as part of the initial set up.
Apr 16, 2016 | Televison & Video
When I press the ok button on my remote to select a channel or recording, the on-screen cursor jumps down to the next item listed and I am unable to select the item I want.
First thing to try is the batteries in the remote. Use new fresh ones, the second this is to see if it is a radio or light controlled remote. If it is radio then you have something causing interference. If it is light control then the remote is probably bad. There are parts in the remote that don't survive falls in some cases
Jan 15, 2016 | Humax PVR9300T HD DVR
I need the code for this TV so I can program my Dish Network Remote to control the volume and power.
Hello! My name is Becki Barned, with DISH Network. This process is very simple. Just follow the steps that I have laid out below. I hope this helps!
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Apr 12, 2011 | Haier HLC26R1 26 in HDTVReady TVDVD Combo
Im trying to program my tv with the Universal remote and i dont know how
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 11, 2010 | RCA Universal Remote Control
Digital sound changed to ANALOG. How to change back to DIGITAL?
It sounds like you hit the ANALOG button. Press the MODE button to get back into AUTO.
Jun 06, 2010 | Denon AVR-3805 Receiver
Blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Sep 21, 2008 | Insignia Televison & Video
Lanier vw-210 dictaphone
It is not a problem at all! The VW-210 & 260 was designed to utilize a two-step erase procedure to prevent accidential erasing of tapes.
1.) Press & HOLD down the TEL button
2.) Immediately press & HOLD down Rewind button UNTIL erase function starts then quickly release both buttons.
Aug 05, 2008 | Audio Players & Recorders
Remote control problems
Replace your battery in the remote. Dont leave something sitting on the remote that is pressing a button down, or it will drain your battery
Jul 06, 2008 | Jensen VM9020TS Car DVD Player
Dark t.v. screen
press the menu button 3 times then the chanel down 2 times then hold the volume up button
Oct 13, 2007 | GE 31GT659 31" TV
RCA RCR860 Remote Control Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
