Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Vacuum won't come on
My Kenmore 25513 won't come on. The carpet attachment/beater bar works, but the vacuum will not come on.
  • 2 more comments
  • Miss Beasley Mar 31, 2008
    I just went to use my vacuum and the same problem the light goes on the hose, but won't work with out the beater
  • Anonymous Sep 22, 2008
    my vacuum will not work other than the beater bar. No suction, motor will not turn on.
  • ediaz76 May 09, 2009
    I have the same problem. I have disassembled the switch and nothing seems to be wrong with it. I'm trying to get to the motor but haven't been able to disassemble the canister. If someonw knows how to do this the help would be appreciated.
  • joedekock May 16, 2009
    My 116-25513506 is doing the same thing. The motor for the vacuum inside the canister is not powering on. We also had it just after a year of owning it, where the switch on the handle did not power it off anymore. It would still turn on/off the brush for carpet cleaning, but it would not power off the vacuum motor.
    President:
  • 1,673 Answers
The switch in the hose maybe bad, motor problem, or some of these cannisters have a relay mounted by the motor, it may be bad.
Posted on Mar 26, 2008
  • Dan Carow Dec 12, 2012
    What is the best way to test the switch on circuit board in handle? How can the board next to the motor be tested? The fuse above the motor is good.
Why won't brushes move on Commercial Carpet Pro Vacuum Cleaner
Luvumuch48tj:
Unplug the vacuum and lay it upside down on some newspaper. Remove the sole plate (bottom plate) with a screwdriver. Pull straight up on the brushes (called a beater bar) and remove the beater bar and belt. Remove the end caps and bearings from the ends of the beater bar (it may take a 2-grunt pull, or CAREFULLY pry the end caps and bearings from the beater bar with a screwdriver) Don't stab your hand with the screwdriver... That HURTS! Once you have the bearings and end caps off, remove the hair, carpet fibers and other gunk from the ends of the beater bar, end caps and bearings. Dribble a little rubbing alcohol on the bearings in the end caps and spin the bearings to clean them... keep dribbling alcohol in the bearings until the alcohol draining from the bearings is clear. Dry the bearings until there is no alcohol in them. Now would be a good time to check the opening in the vacuum head and the hose going into the body of the vacuum for clogs. Reinstall the bearings and end caps on the beater bar and reinstall the beater bar with a new belt in the machine. Reinstall the sole plate. Your machine should run like new.
Feb 15, 2013 | Carpet Pro CPU-2T Commercial Upright...
The "rug mode" (when you
pull out contents - gently off beater bar. Push reset button.
Sep 03, 2011 | Kenmore 25512/ 25513 Progressive Canister...
The beater bar won't turn - the belt is fine. Any other suggestions?
Can you pull the bar and check the end caps to be sure they spin seperate of the bar? Also look at the wheel from the motor that turns the belt. This may be spinning on the shaft which could be caused by a broken pin.
Jun 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Smell coming from vacuum when using beater bar
Check to see if the Belt is broke or a build of dirt is were the belt is . Make sure the beater bar is sitting in place .Best of luck Ed.
Jun 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
I have a Kenmore progressive cannister vacuum cleaner.
There should be a pile height pedal on rear of the attachment, just behind the where the wand goes into it, near the handle release pedal. Just keep clicking on it to go through the height settings.
Please rate if this helps :)
Mar 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
494 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
