Question about Whirlpool Calypso GVW9959K Top Load Washer
It has FL on the machine
It stopped working the other night and has FL on the display. It's holding some water. This is the first problem I have ever had and we've had the washer for about 6-7 years.
  • KitKat1980 Mar 24, 2008
    FL shows on the screen; how do I clear the FL from the screen and get my machine working again? Machine keeps beeping and flashing...driving me crazy. Help!!!! Please.
  • 4 Answers
I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was clogged with a penny. The original external drain hose has a valve that keeps water from coming back into the washing machine. The penny had lodged in the vlave. On the second occassion, a piece of a hankerchief was caught in the drain pump. This pump has a "propeller" that pulls the water out of the washing machine and pushes it out to the external drain hose. I took it off the drain pump motor and tried to clean it. The original pump is solid and you can't take it apart to clean it. I did the best I could, then put it back on. It made a loud noise when draining. Whirlpool no longer sales just the drain pump, you have to buy a complete new pump and motor combo. It costs about $70 on e-bay (new). It is fairly easy to install (30 min). The good thing about the new pump is that you can take the cover of the pump off without taking the pump motor off. The third time I took the pumpef cover off and found a penny lodged in the pump. After taking it out, the machine ran well.
Note 1: A good way to drain your washing machine is to take a hose pipe and put it in the top of the machine and then use a manual air mattress pump (in reverse mode) on the opposite end of the hose that you put outside. After several pumps on the air mattress pump sucking the water through the hose, you will create a suction that will keep flowing until much of the water is out of your tub. Be ready with several containers to catch the rest of the water when you take the hoses off the pump.
Note 2: Check pockets well to keep things from getting into the drain system. Use a delicate wash bag (a mesh bag) to wash undergarmets, hose, hankerchiefs, and other thin items that might get sucked into the drain system.
Posted on Mar 23, 2008
What is the fl code mean
Hello & Welcome to FixYa
FL error indicates flood condition and is caused due to any overfill condition that occurs inside the washer. To clear the display you can press and hold the STOP/CANCEL button. Usually this error is caused when overfill switch trips due to excessive water in the tub. You can also try to clean the drain hose and check the water inlet valve. Please get back to me if you have any other questions.
Kevin
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I am receiving an FL error, how do I get the machine to reset and drain?
Hello
Kevin
Nov 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The wash machine stopped working and is flashing FL
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
It says FL
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Jul 15, 2009 | Kenmore Washing Machines
My kenmore elite reads fl and stops working,
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Clothes Washer
HI There I will help you
I am looking for the answer please be stand by.
Aug 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Whirlpool Calypso GVW9959K Top Load Washer Logo
138 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
