Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP1300
Ink absorber full reset.
Have been trying various 'press reset/press power/hold down both/release one/press 3 times' etc suggestions, but none seem to work.
Can anyone assist please?
I guess even if I was able to get to these elusive absorber pads and remove/clean/replace them, as there's no 'sensor' creating the error message - rather a pre-set by Canon 'time-out' - then it would still say the pads are full?!
This modern throw away world is depressing, why aren't things built to last, why do these big companies get away with presetting things to break down just after the guarantee expires so as to charge us more money to get fixed/buy another new product? You'd think that at least the save the environment mood would force them to have to do better?
Sorry for rant. Extremely fustrated...
  • joelzky Aug 15, 2008
    what should i do if the printer say "The waste ink absorber is almost full.
    Press the printer's RESUME button to restart printing".can u help me?plz give me some solution in canon ip1300
Downlord driver canon pixma ip1200
Posted on Mar 23, 2008
SOURCE:
Waste absorber full. How do we empty?
Resetting The waste ink absorber is almost full message on Canon pixma IP3000.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME 3 times. The indicator should be orange.
6: Press Power to set data.
Hope it helps.
May 17, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
An error occured. ink is running low. view the ink details the ink absorber is full what the solution is that problem?
Ink absorbers do fill up and can be replaced.....however the printer can be placed on a tin foil sheet as a safety shield.
To reset the printer, with it turned "ON" remove the power cord from the wall plug. wait about a minute.
Hold down the "ON" button and and plug the printer in again while still holding the button down. Count down from 15 and when your done release the power button.
The printer is still off so again press the "ON" button.
The absorber is now reset, but the printer does have waste ink inside that can leak out........you are warned!
Sep 22, 2010 | Canon PIXMA iP1300 Printer
I have a IP3000 Pixma and the waste ink absorber is full. Where is the waste ink absorber and how do I access it to clean it??
The absorber is at the bottom of the printer but you don't have to clean it. Even cleaning will not make the printer work. All you have to do is reset the ink tank counter. Here is the procedure:
1. Turn off the printer.
2. holding down Resume/Cancel press POWER - indicator goes on green.
3. release Resume/Cancel, continuing to hold down POWER.
4. press button Resume/Cancel 2 times holding POWER, then release all buttons.
5. when the indicator illuminates GREEN - press button Resume/Cancel four times
6. turn off printer pressing POWER.
Aug 05, 2010 | Canon Pixma iP3000 All-In-One InkJet...
Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
Aug 31, 2009 | Canon PIXMA iP2000 InkJet Printer
The ink absorber is full
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
just send me your email
Apr 02, 2009 | Canon PIXMA iP1300 Printer
MY PIXMA iP1300 keeps error
since canon printers need service tool to reset the waste ink counter, i suggest that you bring your printer to an authorized service center in your area to have them reset the waste absorber counter and clean it as well.
Feb 15, 2009 | Canon MP610 Photo All-In-One Printer
Waste ink absorber full
It's Very Simple
Just Enter in Service Mode of your printer and clean absorbers count.
To enter in SERVICE MODE
1) Power off Printer
2) Push and hold "Resume" button and then push and hold "Power" button
3) Hold the Power button, then release and 2 times press Resume button
4) Led indicators must change
5) Release all buttons
6) Then printer in Service Mode
(If something wrong, repeat 1-6)
To clean absorber counter,
7) Press "Resume" Button 4 Times and after press Power button. It's all! Your absorber count is EMPTY!
In SERVISE MODE you can do several useful things:
To print Service Nozzles test, press "Resume" 1 time and press Power
To print EEPROM data, press Resume 2 times and press Power.
DO NOT press Resume 3 times and POWER. It will reset some EEPROM data settings
Any Question mail me: ossipenko(prettydoggy)gmail.com
Dec 13, 2008 | Canon PIXMA iP3500 Printer
Canon Pixma ip1300 Ink absorber is full what can i do
another solution for a quick override is to unplug the power lead from the back of the printer. With one hand hold down the power button on the printer whilst simultaneously plugging back in the power lead. When the light is back on, take your finger off the power button. You may need to press the power button once more, but this should 'override' the problem until the next time you turn your printer off.
Mar 26, 2008 | Office Equipment & Supplies
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
664 people viewed this question
Clive
Clive
old marine
old marine
Ekse
