Question about Lanzar 2H 1000W MOSFET AMP Car Audio Amplifier
Car Amplifier My amp is 2000watts, with a 500watt sub and 260watt 6x9s attached, it was working for about half a year then suddenly stopped, ive replaced the fuses and disattached then reattached all the wires and it still wont work, it gets power to it but istead of the green light coming on a red light does??
  • 807 Answers
Check the power transistors which usually have their cases screwed to the main heatsink/body of the amp case. They are usually large black cases with 3 legs soldered to the main board.
If any of them are shorted out inside the amp will go in to protection mode. you can test them in the circuit but it's best if you can detatch at least 2 of the legs when testing. If you don't understand the meter readings for transistors you can test them with a continuity tester which will bleep if the transistor is shorted inside.
First put the two probes from the meter on to the first 2 legs, if it bleeps it's probably shorted in side, if it does'nt that junction of the transistor is probably ok.
Then try leg 2 and 3 and the same for leg 1 and 3.
If all 3 legs bleep which ever way round you do it, the transistor will need replacing.
Depending on the power of the amp there are 8 large transistors, 4 for each channel.
Good luck with it.
Posted on Mar 17, 2008
My legacy 12 inch subs are making a crackling sound what can do?
Hi rodneybarton
The problem of your unit may be its amplifier. You need to open the box and inside of it, there is a component that attached on the heatsink you need to replace that one. or better send your unit to qualified technician.
Dec 29, 2013 | Jl Audio Car Audio & Video
I have a 400w rms @ 4ohm sub. What amp do i need? If i want to connect it via 2 channel, bridgeable amp, what wattage does each channel need to be? Do i need a second amp for 2 6x9s?
almost any amplifier amp would push a 400 watt sub. try to stick with a name brand, and steer away from no name brands like boss, jensen, etc.you will only need a 2 channel amp to run your sub.you will need a second amp to run your 6x9'sor you could get a 5 channel amp, and run all your speakers, and the 5th channel for your sub
Oct 25, 2012 | Car Audio & Video
I have 2 amps instalkled in my car one is sony 1200w 2 channel amp for speakers and one is solid audio f2500d for 3 subs my sound and every thing was good but suddenly from yesterday im having trouble when...
First disconnect the CD head unit from the sub amp and see if the other amp works. If yes, the problem is the wires to the amp, the amp itself, or the subs/sub wiring. If no, the problem is the head unit--probably an internal short.
If the other amp works with the sub amp disconnected, reconnect the sub amp to the head unit, but disconnect the sub wires from the amp. Try the CD player. If the amp goes to protect with no speaker wires attached, the amp is bad. If the amp is OK, the problem is the subs or sub wires. Hook the wires up to the amp again, but disconnect them from the speakers. Try the player again. If the amp goes to protect, the problem is the amp wiring. If not, the problem is the subs. Check the impedance of each sub using an ohmmeter to determine which amp is out of spec.
Please let me know if you have questions, and thanks for using Fixya.
Jun 11, 2011 | Solid Audio F2500D 1-Channel Amplifier Car...
It worked for a week and now im getting no power to my subs
if it stopped suddenly i would check the fuses and work your way back to the where the remote start wire is attached. if you where pushing it hard the fuse is likely. also check the connections on the amp closely.
Jan 28, 2011 | Sony HK720-4 Kole Audio 4 Channel Car...
Why do i need to open my gain up to 3/4 to full turn inoder to achieve a loud bass?Im using punch 2400 amp and 2 12" kicker.
the amp may not be powerful or your setting on the cd player is not right try adjusting the cd player. turning the gain all the way up will damage your subs even go above halfway
Sep 19, 2010 | Rockford Fosgate Punch 801S Car Audio...
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
Amp and subs just stoped working
Sometimes power problems are not visible. Did you check the voltage at the amplifier with a multimeter?
Dec 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
No power to 6x9s ??
It looks like the internal amp compnents may have a problem. I would suggest getting a schematic and seeing if the audio can be traced from the input to the point of the problem.
Jan 26, 2007 | Blaupunkt THA275 Car Audio Amplifier
Car Audio & Video Logo
63 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
