Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
My sylvania wont turn on.
The circuit breaker in my house popped, i flipped it back on the surge protecter caught a surge, i tried it again but the protecter did not catch the other surge and the tv turned off and has not turned back on. The red led light is on all the time, it just won't turn on can someone please help!
    Problem Solver:
What is the make and model for your unit? Which state are you located in?
Posted on Mar 23, 2008
I flipped the main breaker in my house and when I flipped it back my unit wont come on what cN I do?
Check the emergency shut off that is outside the house next to the condensing unit.
Jul 20, 2015 | Heating & Cooling
Arcing at rear vent, blew circuit breaker, previous voltage imbalance to house
i would replace all of the wiring and install a higher grade fuse box. Who knows what the army could have setup in there.
Aug 31, 2008 | Sharp R-510HW Microwave Oven
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 18, 2013 | Water Heaters
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
We had a thunderstorm with lightening in the area. The LG was plugged in at the time, but NOT turned on. after the storm, the tv will not turn on. the little green button turns from red to green...
As an electrician, when someone loses more than 1 item of electronics in a day, its almost
always traceable to a nearby lightning strike, accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
The converter box may be replaced by DirecTV, you'd have to contact their customer
service at http://www.directv.com/DTVAPP/content/customerservice
If desperate, you could try replacing the entire TV power supply as a module, but even this provides
Aug 17, 2011 | LG Televison & Video
Both of my tv's died yesterday. My apex wont turn on anymore an the panasonic has no picture. Whats wrong.
As an electrician, when someone loses more then 1 item of electronics in 1 day, its almost
always traceable to a nearby lightning strike, accompanied by a lack of surge protection for
If desperate, you could try replacing the entire power supply as a module, but even this provides
Aug 15, 2011 | RCA F36450 36" TV
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
Hi, I have a Rheem water tankless heater and there was a storm lastnight so suddendly I have no hot water. What can It be?
1) All tankless water heaters require voltage to operate electronic sensors and circuit board.
This is true for gas and electric tankless.
2) Check that circuit breaker is not tripped. Push circuit breaker all the way one direction and then all the way back other direction.
3) There are fuses located inside the tankless unit, so check your manual for location of each fuse.
Manual is filled with useful maintenance and troubleshooting steps.
4) Before calling service technician, open following link for troubleshoot resources including manuals, Rheem on-line chat, and useful links for maintaining tankless water heater.
5) If you had nearby lightning strike, I don't know if your tankless is protected from surge.
I recommend whole-house surge protector for tank and tankless water heater electronics, and household circuits. Surge protection is installed in main breaker box, and is replaced after each surge event. Separate protection needed for co-ax TV satellite, co-ax surge protection can be found on some ordinary power strips.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Apr 11, 2011 | Rheem Tankless Hot Water Heater...
Came home from work to find that my circut breaker was tripped for my furnace...what and why caused this...i flipped the breaker back on and smelled like it fried the control board....why did it do this
The most likely cause was a power surge. The surge from the power line into your house wil fry the board and trip the breaker at the same time. Then when you turn the breaker back on it will continue to fry the board....
Whole house surge protection can help to stop some of the surges, but may not toally protect you from them. Some are too large to be completely stopped with normal surge protection devices.
There are many deivices out that will provide surge protection and some like these that will provide surge protection and can help to save you money.
Check it out here...
www.cutyourelectricbillnow.com
Heatman101
Mar 13, 2010 | Heating & Cooling
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
169 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
