Question about Kenmore 98702 Stacked Washer/Dryer
Tub wobbles terrably in spin mode
Why does my washing machine in spin mode always sounds off balance with a terrable banging sound that i could hear out side
  • 2 more comments
  • gend Apr 26, 2008
    I have the exact same problem with my unit
  • Anonymous Apr 29, 2008
    same
  • kopp123 May 13, 2008
    Having the same issue. It's been getting progressively worse over the last two weeks, starting with just being loud, it's now banging really loud and shaking the whole machine. I no longer feel comfortable using it...
  • robnewporte Dec 27, 2008
    My Drum wobbles and bangs against the side of the washer in spin mode and more recently in the wash mode as well. I'd like to fix it myself but need some assistance, any suggestions?
May be repairable w/o new parts by opening up machine and reinserting spring (via lifting the tub and twising the spring) onto rod of shock absorber(s) if they have separated. Overloading of my light duty machine has cause a couple instances of separation casing the severe unbalance and banging -- which I've fixed per above.
Posted on Apr 27, 2011
    Genius:
  • 1,036 Answers
This is normally caused by defective dampers. Just like car suspension, these even-out the vibrations of the drum.
When worn, the drum just bounces wildly on it's springs.
The metallic banging should be avoided by foam buffers fitted inside. These frequently fall off unnoticed. They just need gluing back on with impact adhesive.
Here is a typical diagram of a washer - click HERE Move your cursor over the damper on the bottom left of the drum to see it.
Look online at spares centres for your make and model, and look for keywords of - suspension, shocks, shock absorbers or dampers for your parts.
They are fairly easy to fit with the back removed.
Thanks for using Fixya! If this has provided a solution, please rate as such. Thanks.
Posted on Jul 03, 2008
    President:
  • 1,294 Answers
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Posted on Jun 17, 2008
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
Why is my washer clicking?
does it spin if you let it run?
Sounds to me like a bad transmission..
do you also have model number
Jun 13, 2013 | Washing Machines
My washing machine makes a very loud banging noise at the start and end of the spin cycle and there is a scraping sound throughout the cycle as though there is metal in the drum. What could be causing...
If you have an older machine it is the un-even load distribution in the wash tub. The wash is not evenly distributed in the wash tub. The wash tub don't spin evenly and wobble instead.
Mar 30, 2012 | Washing Machines
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
Hi, I have a Kenmore 70 Series Model: 110.4767292 washer. I washed a heavy bedspread in it the other day. It went throught the cycle fine but when I was taking the spread out of the washer I noticed...
Most tubs are wobbly, it should be fine. I would wash a regular load and pay attention to any sounds you may hear. I would only be alarmed if you hear something out of the ordinary. The washer would have to severely go out of balance to break or damage anything, so if your confident it did not bang around too much it should be fine. Hope this helps.
May 12, 2011 | Kenmore Washing Machines
While doing a load of clothes this afternoon, the washing machine starting making a very loud off balance banging sound, I rearranged to load but the basket continued to wobble wildly. Please help!!
The tub assembly is suspended by either coil springs or heavy rubber 'O' rings. One may have come loose or has broken. You may be able to spot the one causing the problem by taking off the lower back panel and examining the suspension while someone moves the tub; keep your fingers clear though-
Mar 01, 2011 | Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The machine does not spin properly. The tub
it sounds like the unit is not sitting on level ground sometimes there are feet that can be adjusted to raise and lower the unit on the front left and right side go to a department store and by a level for a couple of dollars and put it on the top exterior of the unit and check it left to right and front to back
Feb 21, 2009 | Maytag Performa PAV2200
CRT color moitor
The "terrable loud high pitch sound" could be the horz. oscillator.
The voltages off the crt should be (+) (-) 11v to 15v DC. Too much on Blue & Red guns will cut them off
Jun 21, 2008 | Televison & Video
Kenmore 98702 Stacked Washer/Dryer Logo
2,753 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
