Our LG WM0532HW washing machine will often not begin the wash cycle after the washing mode has been selected. (note the power is on -- the start button has been pushed and the lights are on). After pushing the mode button many times (some times 10 or 100s of times over several minutes) the wash cycle will start. We called a service guy who unplugged it and plugged it back in and it worked ok. We/he thought that the computer must have crashed. Now, however, plugging and unplugging (to reset the computer) doesn't seem to have any effect. I would like to contact LG about this, but I can't find a number to call or a web page. Thanks, Gregg Beytin
    Guru:
  • 1,894 Answers
I think the problem in washing machine is is the motor
Posted on Mar 16, 2008
  • dewan nafees ahmed Mar 16, 2008
    is this the problem you have with your computer or with the washing machine>?
    Toll free no : 1860 180 9999
    ask them
    they will give some more numbers for you to help
I have a LG Tromm it starts running in wash mode then a few mins. into cycle it shuts off no codes there is nothing on display
Here's a reset that could work:
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE. Good luck
Mar 07, 2018 | LG Washing Machines
LG wm0532hw starts it's wash cycle then stops with the code LE flashing. Tried to reset the washer already and it did it again after reset. Tried no laundry in the cycle to see if it was to heavy and same...
check out youtube.com, repairclinic.com or appliancepartspros.com search for motor sensor replacement or hall sensor replacement. easy repair. $20 part. 30 minutes time. a know issue on earlier lg washers. lg has enhanced the part to make it more durable. make sure you get an lg part, not an oem equivalent part. part no. 6501KW2002A
Mar 18, 2015 | LG Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Is there any way to force LG Tromm to do spin only cycle. Machine seems to be broken, no draining water, or doing anything else. Thank you! B
1. Turn on the washer.
2. Press Spin Speed button until desired speed selected.
3. Press Start
Note: Do not select a wash cycle.
Feb 07, 2010 | LG Washing Machines
PF(Power Failure) error appears each time the washer starts.
PF simply means there was a power failure since the last time you used the machine.
To clear it - simply power cycle it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer spin and not enough water
Spinning both ways is pretty normal. You did not say if your clothes were clean in the end. You may not see much water when it washes, when it rinses you may see about 1/3 thru the glass. Careful with the door aft wash, wait for 2 minutes before opening.
Feb 28, 2009 | Washing Machines
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
