Question about Hotpoint Ultima WF860 Front Load Washer
Error code f 05
I have got hotpoint wd640 front loader,it takes the water in than washes when it comes to rinse it stops and error code f-05 appears. thank you Hiya gor a Hotpoint Ultima Super Silent that when ready to spin out it stops and slashes error code F 05. Does the same when doing an empty wash. the filter has been checked, emptied and washed out.
  • 4 more comments
  • denjustden Mar 17, 2008
    yup, got the same error code prob as vikki........f 05. help!
  • GGL70 Mar 23, 2008
    YIP Same here , F5 and won't drain
  • janefield Apr 13, 2008
    machine will not empty of spin F05 flashing
  • VikkiCowie Apr 18, 2008
    Hiya thanks for that, although we had already done that you would not believe what was in that!!! Almost enough for a pint!
    As it turned out the drainage hose was blocked, so once that wsa cleared we were ok. No need to buy a new machine thankfully.
  • Anonymous Jan 18, 2009
    Yep same problem F05 but great advise from gigwiggin and all solved in less then half an hour. Cheers!
  • Anonymous Mar 18, 2014
    Stops with fault F-05
  • 5 Answers
This worked for me and I made 25p for the trouble:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
Great advice. That sorted the problem. And it made me £2.05 !!!
Yeah just undo the big jubilee clip, pull the big black hose down, take out whatever's blocking it, put the hose back on...and voila!!!
Thanks Gigwiggin...topman.
Posted on May 17, 2008
Same solution for me. Removed the front filter plug, found a very basjhed about 20p and a small knot of tangled fibres. Removed and works a treat
Posted on May 10, 2008
I have the same problem any solutions please
Posted on Apr 09, 2008
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Wd640 problem not pumping out f-05
Error code means pressure switch jammed on full.
Remove lower rear panel of washer
Remove large black hose fastened to bottom of drum
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well
Please rate my solution.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
f05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Oct 14, 2008 | Hotpoint Aquarius WD640 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Error code f 05
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Sep 17, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
511 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
