Question about Interlink Electronics VersaPad (VP6100) Touch Pad
Ryger px12 powered controller
Locked out and we need to re-set it. Do you have a manual that may help us?
Hi Support, I have an NAS Device and one hard drive in this unit has failed,I with like to have this replaced,
Simply swap it out. Make sure you get the same drive type, i.e SATA, IDE, It's easy to replace.
Oct 02, 2014 | EMC Computers & Internet
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Washer wont start it has a control panel lock tried to power it off no help
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. You also cannot clear it by unplugging the appliance. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The red light for CONTROL LOCKED will not go off nor can I turn the machine on. Help!
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Mar 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
On some front loading washer there is a button that when held for 3 to 5 seconds will lock the control panel so young children can't change settings. Look at your control panel for writing under a button that will tell you to hold down to lock or unlock panel.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My control lock is set on how do i get it turned off so i can wash?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Jan 19, 2010 | Washing Machines
Control locked what can i do?
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this helps you.
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked and will not run or open....even tried to reset power
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
If the washer door will not open, the following link explains how to use the manual release to open the door:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have questions, please let me know. I hope this helps you.
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
to PR manager of your MI service company My name is Phil Baranov, I write for the Russian-language paper issues and on-line- resources on the themes of musical technologies, musical tools, DJ-equipment, pro-audio and show business. Possibly you know already, that since July this year Russia entered the force the new customs rules, which allow for those living in Russia to purchase goods and services from abroad in the larger measure (less VAT, more weight etc.). According to this we have the increased interest in the possibilities of the service of electronic musical tools outside the Russia. Could you be so kind to give to me the interview (via email, ICQ or so) distantly on the standards prices, accepted in your company by after-warranty reparations of electronic musical gear, diagnostics, periods, accepted online pay procedures, the most typical reparation conditions, etc. It was obtained the reputation of the history of the sufficiently long and expensive post-guaranties repair of synthesizers, studio, music computer-related and DJ-gear In the Russian-language sector of the Internet. I would like to describe to our readers, as it proceeds with this in the entire remaining world. Could you answer some questions about your company, it's qualified personnel, business processes, standards of maintenance, accepted prices and brands, etc. Inform me your decision anyway, please. With the best regards, Phil a.k.a. mix2@
Mar 01, 2017 | Interlink Electronics VersaPad (VP6100)...
See all Interlink Electronics VersaPad (VP6100) Touch Pad Questions
Interlink Electronics VersaPad (VP6100) Touch Pad Logo
165 people viewed this question
Top Interlink Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Interlink Computer and Internet Expert? Answer questions, earn points and help others
