When temp is set on hot water--hot water shuts off & cold water comes out
When the washer is on Hot Water, the hot water comes out for about 60 seconds, then it switches to cold water. Even the second rinse is cold water instead of hot water.
What is the problem?
  • 2 more comments
  • bmcm13059 Mar 23, 2008
    Hot water runs for about 60 seconds then shuts off completely during fill stage. What is the problem? Do you still think it is the solenoid that the water hoses come into?
  • Anonymous Mar 14, 2014
    washer is sit on cold water but hot water is coming out
  • Anonymous Mar 17, 2014
    Cold water only coming out of tap
  • Anonymous Mar 22, 2014
    WHEN THE WASHER IS SET ON COLD WATER ONLY VERY HOT IS COMING OUT
    Scholar:
  • 178 Answers
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Posted on Mar 16, 2008
  • Robert Fawbush Mar 24, 2008
    I do believe it is the solenoid. It isn't registering that the hot water needs to continue in with the cycle, however, my wife does ALL laundry on cold wash any way, it helps to eliminate shrinkage.
Why does cold water mix with the hot when the switch is set on hot
Depending on the age of the unit you may be looking at a faulty switch. Sometimes the contacts for the cold water solonoid on the switch may be fused shut and therefore you will always get cold water no mater what you select. If hot water is what you need the easy way to do this is select hot water and close the tap for the cold water until needed again. Hope this helps
Sep 06, 2012 | Admiral AW22 Top Load Washer
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
Cold water starts and stops when washing
sounds like your washer has an auto temp. control if so the washer mesures the temp of the water and put in the manufacture set temp for that setting this board could be bad alowing only cold water to come into the machine. you could also have low hot water pressure at the washer be sure the hot water is turned all the way on. you may want to check to make sure no trash is in the hot water side of the water valve there is a screen in there where the hose conects you can remove that screen and clean it im sure one of these solutions will help you
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
