Question about Bogen Communication Bogen Manfrotto 3047 Delux 3-Way Pan Head Tripod
Bogen Manfrotto 3047 head
I have had this tripod for years but do not use it all that often.  I don not have the manual and find that the quick release head isn't intuitive to use. I know that the camera screws onto the piece and the knob underneath turns the screw to attach the camera.  However, each time I use the tripod, I have trouble getting the screw to "lock" and secure the camera properly. Also, I haven't the foggiest idea how to quick release the camera even if I have it locked onto the plate.
Can someone assist me with this?  Can you explain, exactly how the screw mechanism locks? And how the lever releases the plate?
Your help would be much appreciated.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Posted on Apr 16, 2008
2 Suggested Answers
  • 10865 Answers
SOURCE: quotation for 3051 & 3047 model
http://www.canogacamera.com/tripods_bogen.aspx?gclid=CP2dprrG5ZgCFQrAGgodwHJ-dw
go to this site and you will find what you need.
please rate my answer as a fixya. thanks
Posted on Feb 18, 2009
How do I tighten my Manfrotto 3265 ? After 15 years of use, it is slipping and not supporting my camera.
Check out the videos at http://bogentripodparts.com/repairs.htm the second on the leftside deals with this problem. They also do reapirs.
Oct 19, 2013 | Bogen Communication Bogen Manfrotto 3265...
I have what was a BOGEN MANFROTTO TRIPOD 3246 WITH 3047 FLUID HEAD PLATE that is discontinued I'm looking for the user manuals.
There really are not user manuals so to speak. If you need service or repair try: http://www.manfrottotripodparts.com/repairs.html If you are looking for more tripod use info try: itripod.com
Apr 03, 2013 | Manfrotto Photography
Bogen 3047 manual
I own 4 of these... what do you want to know about it?
Sep 09, 2012 | Manfrotto Bogen / 3047 3 Way Pan-tilt Head...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
Who do I contact to get repair of quick release's on 519 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Jan 18, 2010 | Bogen Communication Bogen / Manfrotto 519...
How do you get the head off the tripod?
There are three small set screw (grub screws) that are under the head, net to the center column. You will have to raise the center column and look under the head. These are slotted screw heads and a small to medium screwdriver should work. You don ot have to remove the grub screws completely, but you should back them out at least half way. The head will unscrew off the center column. The gray part below the head is half the head attachment and half the center column end plate so it should separate in the middle line between the two.
Dec 25, 2009 | Bogen Communication Bogen Manfrotto 3047...
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Jul 02, 2007 | Bogen Communication Bogen - Manfrotto...
Photography Logo
700 people viewed this question
Top Bogen Communication Photography Experts
pontelemon
pontelemon
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
