Question about Refrigerators
Water on the insde of fridge.
I have a Fridgedaire, I also have alot of water on the bottom inside under the fruit drawer, how do I fix this. It's brand new.
    Scholar:
  • 178 Answers
Locate the drain tube that comes from the freezer. Even though it is brand new, the tube may have been jarred loose during shipment. When the freezer gets a certain amount of ice build up on the coils, a defrost timer turns on and melts the ice. In theory, it is supposed to melt into a drain tube and down to the bottom of the fridge where it then drips into an evaporator pan. Check in the back also for a plastic tube and try to trace it from there.
Posted on Mar 16, 2008
6ya staff
SOURCE:
Water in the fruit and vegetable draweres
You might have the frig. temperature set too low. Set it at 38 deg. check actual temp. with gage. What happens is ice builds up in the drain tube that runs down to the bottom when the fridge defrosts therefore causing water to run into the veg. drawers. Ice buildup is preventing the water from running out at the bottom where it should. Just raise your fridge temperature a little and the problem should go away. Hope this helps.
Feb 04, 2013 | Samsung RF265AA Bottom Freezer French Door...
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
54409 // water accumulates under veg and fruit drawers?
Look inside at the back to see if there is a collecting troff which collectes the water runing down the cool plate. In the middle of the troff is a run off hole which takes the water outside to the back to an evaporation tray. if this hole gets blocked it floods the fridge and you know the rest. Some fridges have a looped plug which you pull out of the troff hole to clear the blockage. I know this as my fridge does this too.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Water comes into the fridge from the freezer.
You have the drain from the coild froze up. The coils defrost and the water cannot run down the drain so it goes into your fridge.
This tip is all about that and how to fix it.
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
Heatman101
Jan 24, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
