Cpu change changing the cpu on a Toshiba Satellite Pro 6100 it calls for the use of silicone grease instead of usual thermal paste is this correct and what type of grease do you use
  • 85 Answers
I would say that you can probably use whatever you want. But if it tells you to use silicone grease, the you probably should so you don't void the warranty.
Posted on Mar 16, 2008
SOURCE:
Clean heat sink on toshiba satellite
Turn off the Satellite laptop and flip it over so you can see the bottom. Push the battery latch towards the outside of the laptop and remove the battery.
Locate the heat sink panel, which will be next to, or including, the two fans that you can see. Unscrew the two to three screws that are holding that panel down, and remove them.
A few models of Satellite laptops use Torx sized-8 screws instead of Phillips.
Unplug the cables running from the two fans to the control board.
You can see the cables coming up from under the fans.
Then unscrew the two to three screws on the fans, and pull up to remove the fan unit from the laptop.
If your Satellite heat sink panel does not uncover the fans as well as the heat sink, ignore this step.
Remove the four screws that surround the heat sink.
Then move the heat sink back and forth to disconnect it from the CPU.
If your laptop shuts down by itself without any reason, check the heat sink first.
Overheating is a very common problem among Toshiba laptops.
Lift up on the heat sink to remove it from the unit.
If the CPU got caught on the heat sink and comes off as well, grasp it by the edges and peel it off the heat sink.
Turn the screw on the side of the CPU socket to unlock it, then place the CPU back in its socket and lock it again.
Blow compressed air into the heat sink and the fans until the dust is removed.
Then blow the air onto the control board to remove loose dust from there as well.
Place some Isopropyl alcohol onto your cloth, or a small brush, and clean the processor and the control board area around the processor.
You will also want to wipe up the thermal grease that is on these components. Make a note of the area where you removed the thermal paste.
Reapply a layer of thermal grease in the areas where you removed it.
The lid of the thermal grease container will have an applicator.
Just spread the grease over the components.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Replace the heat sink, then the fans and finally the heat sink panel cover.
hope this helps
Oct 09, 2012 | Toshiba Satellite L505DGS6000 Notebook
My toshiba satellite p305 s8825 gets really hot what can i do?
check the fans
Turn off the laptop, close the lid, flip it upside down and rest it on a flat surface.
Locate the cooling fan, which is under the vents on the bottom of the laptop.
Spray the compressed air can inside the vents for 5 to 10 seconds.
Change the air direction until all the dust is cleared.
check you CPU make sure its securely seated and has thermal grease
hope this helps
Oct 09, 2012 | Toshiba Satellite P305-S8824 P305-S8825...
Toshiba p300 manuel
How to take apart a Toshiba Satellite P305 and Satellite P300 series notebook.
In this case I'm working on a Toshiba Satellite P305 notebook. Also, you can use same set of instructions for taking apart a Toshiba Satellite P300 notebook.
STEP 1
Turn off the laptop, unplug the power adapter and remove the battery.
In the battery compartment remove three screws securing the keyboard bezel.
STEP 2
Remove the keyboard bezel with a small flathead screwdriver.
STEP 3
Remove two screws from the keyboard.
STEP 4
Lift up the keyboard as it shown on the picture and place it upside down on the palm rest
STEP 5
Unlock the connector on the motherboard and release the keyboard cable.
Remove the keyboard. \
STEP 6
Remove one screw securing the CD/DVD drive.
STEP 7
Push the CD/DVD drive from the laptop and remove it.
Electrostatic Discharge (ESD) can kill your computer
ESD can permanently damage your laptop. Always ware ESD wrist strap when you work with internal computer components.
How notebook screws are marked
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized.
Removing Memory Modules
Carefully spread latches on both sides of the memory slot with your fingers.
Carefully pull the memory module from the slot by the edges.
Removing Wireless Card
There are two antenna wires connected to the wireless card.
White wire connects to the main connector on the card.
Black wire connects to the auxiliary connector on the card.
To disconnect the antenna wire from the wireless card grasp the connector with your fingers and unsnap it from the card.
Carefully spread latches on both sides of the wireless card slot, just enough to release the card.
The wireless card will pop up at 30 degrees angle.
Pull the wireless card from the slot by the edges.
Disconnecting Keyboard
Before you pull the keyboard cable from the connector on the motherboard, you'll have to open up the connector.
After the connector is unlocked you can pull the cable. Be very careful with the connector. If you accidentally damage the connector, you'll have to replace the motherboard.
Removing Modem Card
The connector is located under the modem and you cannot see it until the modem is remove. After the modem is removed, disconnect the cable (on the left side).
\Usually the modem is secured to the motherboard by two screws. Remove them.
To disconnect the modem from the motherboard lift it up.
CPU came out attached to heatsink
In some cases, when you remove the heat sink, the CPU might get out attached to the heat sink. DO NOT install it back into the socket like that, separate the CPU from the heat sink first.
CPU came out attached to the heat sink because thermal paste dried out and glued the processor.
Insert a flathead screwdriver between the CPU and the heat sink surface. Carefully rotate the screwdriver until the CPU separates from the heat sink.
\Lift up the CPU and install it back into the socket on the motherboard. Now you can safely remove old thermal paste and apply a new layer of paste.
Removing and Installing CPU
The CPU is locked in the socket. Before you can remove the CPU, you'll have to unlock the socket. Use a flathead screwdriver and turn the socket screw to "Open" position.
Lift up the CPU by the edges. Be careful, there are a lot of fragile pins on the opposite side of the CPU. You should be able to install the CPU back into the socket without any force.
There is only one correct way to install the processor into the socket. Both CPU and socket are keyed. When you are installing the CPU, make sure to match pins on the processor with holes on the socket.
Before applying thermal grease on the CPU, clean the surface with alcohol.
After the CPU surface is cleaned, apply a small drop of thermal grease.
Spread thermal grease evenly and install the heat sink.
ATTENTION! If you forget to lock the CPU in the socket, the laptop will not boot. If you install the heat sink without applying thermal grease, the CPU will overheat.
Dec 20, 2011 | Computers & Internet
My toshiba satellite pro 6100 will not turn on. The battery light and power light turns green but it will not turn on.
The problem could be your display. Use the VGA port on the side of your laptop to connect it to a computer monitor, this will let you know if your system is posting or not. (If you see the Boot Screen it is posting).
May 19, 2010 | Toshiba Satellite Pro 6100 Notebook
Thermal Paste
From the word itself it is a thermal paste that can hold the CPU and iot helps out to prevent the heat coming from the processor, when the cpu fan operate/spin it also that helps that processor to cool down.
You may try a toothpaste as a substitute for it you will need a "white base toothpaste" just put only a small amount into it.
Let me know for any clarification
Feb 06, 2010 | Spire STARS-420/2 White grease Thermal...
Audio Hardware On toshiba Satellite pro 6100 Wont install
Please send your laptop details to [email protected] and I will find the correct driver for you and e-mail it to you.
Jan 02, 2010 | Toshiba Satellite Pro 6100 Notebook
ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
Jul 16, 2009 | Toshiba Satellite 5005-S504 Notebook
CPU overheatsToshiba Satellite A105-S4134 need to replace system board and cpu
Open it u, blow it out really well with a can of compressed air.
Also I would reapply some thermal grease between the cpu and fan, like arctic silver 5. You should clean the old grease beforehand.
The Toshiba Satellite A100/A105 TECRA A7 Maintenance Manual is here.
Jan 12, 2009 | Computers & Internet
Upgrade CPU In my SAMBA SM-1845
Hi, as long as both chips are slot 478 it should work fine, you wont need to change any bios or jumpers, just open up the computer, remove the heatsink, lift the lever and remove the CPU.
Insert new processor.
you will need thermal grease at this point, you need to apply a little amount onto the cpu, and make sure the old thermal paste is removed from the heatsink and then refit the heatsink & fan.
other option is fit the new cpu and purchase a new heatsink & fan, they usually come with the thermal grease, a new heatsink will cost about £10 or themal grease by itself will cost about 2-3 pounds.
just make sure you have new thermal paste before you remove the heatsink as the processor will get damaged otherwise..
Hope this helps
John
Jul 31, 2008 | FIC Samba SM-1845 (SM1845GV) Barebone
Open Questions:
SBCGlobAL TecHNicAL SuPPoRt @[+1-855*536.5666]#OO#**'+ SUPPORT NUMBER It doesn't matters that which kind of problem faced through the users,the support 1*855*536*5666 team that has been appointed for Sbcglobal is quite intelligent and impressive in solving the technical difficulties belongs to different categories.For contacting the technical team users needs to do the instant connectivity over the help number 1*855*536*5666 that has been given on the website.First the users would be accessed through the experts by the help of the remote access technique that is quite convenient for the detection of the respective issue.The technique that would be used to solve the technical problem depends upon the criticality of the problem.One user can have more than one email account. May be user wants to close any one and thus want to have all the contacts in another existing account. It is not difficult to have the contacts transfer from one account to another 1*855*536*5666 one. Sbcglobal email users can call our anytime to get connected with one of our highly trained technicians who are available round the clock to offer most smart solutions to any issues. Not just this, our team of technical support 1*855*536*5666 also offers 100% reliable technical resolutions through SBC yahoo DSL support number and . Our email specialists have been highly trained and are totally adept in offering the best solutions for just about any SBC customer care related tech support issue that you may be facing. This is called as Import/ Export.
Oct 22, 2019 | Yahoo Computers & Internet
SBCglobal MAil HeLpliNe {1.855.536**5666}#[email protected] NuMbER TECHNICAL This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 22, 2019 | Best Computers & Internet
Computers & Internet Logo
43 people viewed this question
Ekse
Marvin
Marvin
