Question about EliteGroup P4S5MG/GL+ Motherboard
Pin connections on p4s5mg/gl /help on hook-up
Need manual for motherboard wiring on pins sequence not exact and one connection not hooked up .also harddrive not auto-detecting
    Guru:
  • 1,894 Answers
Please give model number in detail
Posted on Mar 16, 2008
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
Jul 30, 2014 | Shuttle AK32 Motherboard
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
Had to get a new power supply for my GT4016. When I got ready to hook up the motherboard power connector I realized the power supply has a 20 pin connector and the motherboard connector has 24 pins. Did...
on the part of the power supply there is another connection with 4 pins the 20 pin and the 4 pins click together then slot into motherboard thats usually wat the problem is theres AT and ATX motherboards see if you have those extra 4 pins hanging loose on the wires they slide into each other then into motherboard
Oct 09, 2011 | Gateway GT4016 Desktop PC
I have a LINDE VI-252 cv/dc power supply and I want to hook up a Hobart 2210 wire feed and I need to know which pins on the back of the power supply to hook to.
you will have to get the user manual for mig welder stores for the exact connections of the wires.
click thois link directly to get the hobart user manual.its not the exact model but near to your model of hobart the connections will be near to same and will give fair idea to connect the parts
http://safemanuals.com/reference-HOBART/1
thanks.keep updated.
Dec 05, 2009 | Hobart Welding Tools
Hooking up case wires to motherboard: ECS M925
If you look at this picture, the pins on the motherboard should be on the far left below the brown slot and above the white connector. The pins on the board are marked with tiny white letters HDD, PWR, RST, SPKR. The USB connection on the board may require a separate header, I can't find a manual to see for sure.
Apr 04, 2009 | PC Chips (M925G) Motherboard
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
I am trying to hook up front panel usb ports.
check out this diagram i think it might help you
http://attachments.techguy.org/attachments/107266d1180693321/standard-usb-pinout2.gif
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
Dec 04, 2008 | Intel Motherboard
Manual for aopen ux945g
I am doing more research and trying to get the manual so please bare with me. I found a site but the manual is not downloading so I'm still looking for you. it seems there is a problem with getting your piticular motherboard manual but i will still be looking. one thing you could consider is looking at a motherboard manual that is simular to yours, because the pins and the RED FIREWIRE wire hook up will be the same, but I will continue on looking for It. also just a little hint on the pins , each set of pins on your board are very close to the intended connection , USB , AUDIO , ECT...
Oct 10, 2008 | Computers & Internet
EliteGroup P4S5MG/GL+ Motherboard Logo
210 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
