Question about Sewing Machines
Kenmore 14 stitch machine
I just got an old kenmore 14 stitch machine and cannot get it to do a straight stitch instead of zigzag. help! Thanks,
  • Anonymous Mar 17, 2014
    i have an old white sewing machine model 9950 and for some reason it won't do a straight stitch only zigzag---i have a manual and read directions but it still won't work any suggestions thanks
  • Sewing Machines Master
  • 1,388 Answers
Adjust the width selector to zero
Posted on Mar 16, 2008
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area:
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
619 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
