JVC turntable LA10
How do I replace the belt on my JVC turntable?
  • mikeflowers Mar 16, 2008
    The platter won't lift off?
  • Anonymous Jul 19, 2008
    Solution offered not worth much. The problem is the PLATTER DOES NOT LIFT OFF LIKE MOST TURNTABLES. So specifically, does anyone know how to remove this turntable??
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Posted on Sep 23, 2008
JVC L-A10: Replaceing belt - Sorry for the delay, but only just found out myself. Do not try to take off a turntable by tapping of hammering. Turn the turntable over to its side or back and undo all the screws underneath that hold the top to the base. When open you will notice the base of the spindle underneath, there is a very small phillips head screw holding the spindle in place - loosen the screw and the platter will pull out. Then you can replace the belt and put everything back together.
Posted on Jun 20, 2011
    Scholar:
  • 105 Answers
Here is the belt type:
http://www.turntableneedles.com/browseproducts/23.6-Inch-Flat-Belt--Medium.html
Most turntables - lift off the platter - remove the old belt - clean running surfaces - stretch new belt around bottom flange of platter - either thruough a hole in the platter or just holding the belt pinched loop the belt around the motor drive spindle or pulley and lower the platter onto the centre bearing.
Posted on Mar 16, 2008
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    AL-A1 turntable won t turn
    take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
    Jan 19, 2014 | JVC Audio Players & Recorders
    Need to replace the belt on my JVC AL-A95 turntable
    To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
    2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
    5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
    6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
    7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correctoperation.
    MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
    Oct 08, 2011 | JVC AL A158BK Turntable
    I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
    I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
    Jan 01, 2011 | JVC Audio Players & Recorders
    How to replace the belt on jvc l-f130 turntable
    You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
    Nov 22, 2009 | JVC AL A158BK Turntable
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    How to replace belt in jvc turntable
    I just got a JVC turntable from a thrift shop today and as soon as I got it home the belt broke. I had a replacement but couldn't figure out how to install it. After taking off the back, which is about 4 screws plus the 4 feet and the grounding screw, I saw a very tiny set screw on the post where the spindle obviously is. I removed this and the table came right off so I could replace the belt. I couldn't get the tiny set screw back but figured I didn't need it and if I ever have to replace another belt, I won't have to take the back off anyway. I hope this helps.
    Jan 02, 2008 | Audio Players & Recorders
    1,770 people viewed this question
     Grubhead
    Grubhead
    Marvin
    Marvin
