Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Foot Pedal was knocked out of alignment
The foot pedal is attached but not is loose and the handle won't lock in the upright position.
    Problem Solver:
  • 17 Answers
If the foot pedel is loose then the spring portions of the plastic ar broken off or the part is install incorectly. We know this from our own experience, we had athe lever replace wrong and when we put it in the right way so it would have spring tension it worked as if new again.
Posted on May 26, 2012
    President:
  • 1,673 Answers
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Posted on Mar 18, 2008
Install foot pedal release on riccar 8800 series
It's not hard to do but is almost impossible to explain how to do it. If you can look at one already installed on the shaft holding the pedal you can see how it's done. Visit your local Riccar dealer.
Jan 12, 2014 | Riccar Handle Release Foot Pedal - 8000...
I took my dyson apart to clean it and it will not click into an upright position.
This is a common problem easy to fix but tricky to explain so please bare with me...You need to put the machine on it's side and if you take the handle and move it up to the point where it stops and won't go any further stopping it from being able to go straight up and lock into place.You need to look at the spot that it is touching and the spot you are looking for should be attached to the foot pedal that let the handel down. The pedal pulls a piece of plastic out of the way so that it can fall back, what has happened is the piece of plastic has moved into lock position but the handle is behind it. you need to manually pull the plastic piece that is attached to the foot pedal out of the way so you can get the handle up straight and then let the plastic piece go and it should be in the right position at this point.
This is the best that I can explain it without being there to show you so please take your time and look at it carefully and you should be able to with my instructions I have given you get it back to normal.
If this has helped you please remember to click on the yes box on your way out and good luck! thanks again for choosing Fixya!
Oct 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
On the ultimate g the drive pedal came out of the machine. tried to slide it in but it will not change the drive mode. take off the bottom to see what is in there?
first you need to remove the top cover before you take the three corner screws out of the bottom. Remove handle, bag , two screws on the scuff plate and stick a flat head in the slot of the scuff plate and pry up. you will have two screws under there and two screws in the front and the top cover will come off. lift up on the plastic foot pedal and it will pop off the transmission. you can now remove the belt off the transmission by taking the three screws out on the bottom. there will be a little metal lever that is splined like the shaft of the foot pedal. that lever needs to be in the proper position for the foot pedal to shift the transmission.
Jan 02, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Foot pedal broken
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=629933
Foot pedal broken
Posted by Monte79 on May 28, 2008
I have Bissell Power Steamer Clear view IIII #3105403. I let someone borrow it (mistake #1) and he over extended the foot pedal that angles the upright during use. The pedal is still connected, but the power steamer is locked in the upright position. There is also a bit of dirty water in the bucket, and i cannot empty it because it's basically locked in now. HELP
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem with your Bissell, it sounds like he bent the handle release lever and you either need to bend it back or replace it depending on the level of damage to the item. Please feel free to contact the Bissell factory to see the best way to fix the problem, it is not an expensive fix however so contact your local vac dealer or get a referral from the Bissell factory for the nearest Bissell authorized dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Broken upright locking mechanism
I need to know what brand the vacuum is. Various brands have different ways of locking the handle, but most incorporate a pedal that engages the handle. It sounds like you will have to replace the pedal. I hope it's not the handle portion. That becomes more complicated and expensive to replace.
Feb 08, 2008 | Vacuums
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
414 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
