Question about Gateway MX3215 Notebook
Laptop gateway mx3215
I use to be able to tap the mousepad instead of using the right click to activate things...Is there a setting that might have shut this freature off?
  • exotic99 Mar 16, 2008
    Thanks for your input, but that didn't fix it..unless I missed a setting..I tap the mousepad and nothing happends..
    Thank you...I enabled it.... set it to the shortest setting, but nothing.. I am very careful with this laptop..I doubt highly anyhting is broke.. I got to just be missing someting
  • 796 Answers
Ya...you can restore the buttons from the control panel>mouse feature
Posted on Mar 16, 2008
    Guru:
  • 1,894 Answers
Yes yu can do it
  • 1 more comment
  • dewan nafees ahmed Mar 16, 2008
    in control panel go to "mouse"
    and there there is last option called click lock.
    just enable that sir
    and then modify it according to your wish by playing with the settings
    thank you sir
    sir is the mouse pad not working completely>?
    i think i am not getting ur problem in right path.
    can u please explain me it in detail
Scroll bar on my touchpad/mousepad not working??
Go to Control Panel > Hardware and Sound > Devices and Printers.
Then, right click on the laptop and select mouse settings. Click on touchpad and go to Gestures. Finally, check that scrolling is activated.
Feb 22, 2015 | Gateway NV53A75u 15.6 Laptop X3 2.1GHz 4GB...
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
I HAVE A GATEWAY MX3215 LAPTOP BUT IM MISSING OR
Go to Gateways site and download the "recovery" disc info....I note that your laptop specs only has 256 MB ram which is too low to run XP. I suggest you need at least 1GB ram DDR2 whixch is the max it will handle. This will really speed it up and is relatively cheap.
Apr 13, 2010 | Gateway MX3215 Notebook
Gateway laptop running Vista suddenly developed an issue with the mouse pad.... double click doesn't respond. However the touch pad works to move the mouse
I have just had this problem with an Acer laptop running on Vista Home. When I double clicked on the actual pad itself rather than the bottons, it wasn't recognising it at all. Wouldn't scroll down or select a folder etc, just if I double clicked on the actual pad. Everything else worked OK.
I tried the solutions above but they didn't work.
Turns out it's the 'Tapping' function that needs to be enabled. Go to Start > Contol Panel > Hardware > Mouse > Device Settings > Then it says devices: and lists what pad hardware you have (mine is Synaptics Touchpad V7.2.
Under the box are 3 buttons Enable, Disable and Settings, presuming yours is enabled go to Settings > Tapping > Enable Tapping. Hey Presto! :-)
Aug 21, 2009 | Computers & Internet
Mousepad, right clicker problems on ibm thinkpad t41
you can try looking at the manufacturers website for a driver update to your trackpoint http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#mouse
Try turning off the tap to click option. This should resolve accidentally dragging things where they don't need to be.
Better option...if you're using this laptop at home just invest in a wireless mouse and set the laptop to disable the trackpoint when an external mouse is detected.
trackpoint=mousepad=touchpad
Jun 10, 2009 | IBM ThinkPad T41 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
Mar 16, 2009 | Computers & Internet
Need to replace my keyboard on a Gateway mx3215.
The best way to replace the keyboard is to first order one off of ebay.
eBay links for MX3215 Keyboards
Next step is to follow the instruction manual from Gateway. Download the following PDF document, and check out page 45 in the PDF document [labled as page 41 in the manual].
Download Gateway MX3215 Hardware Manual
Best of luck!
Mar 16, 2009 | Gateway MX3215 Notebook
Mx3215 memory upgrading problem.
Here is a link for you open this page and enter your serial no.
Click Here
This page will tell you which one is campatable with your system.
Thanks
Iqbal
Mar 17, 2008 | Gateway MX3215 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Gateway MX3215 Notebook Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
