Question about Logitech Z-5300 Computer Speakers
SPEAKER FRONT RIGHT NOT WORKING?
I HAVE LOGITECH Z5300 AND WHEN I WAS PLAYING A GAME THE FRONT RIGHT SPEAKER STOP WORKING WHAT CAN I DO OR WHAT IS THE PROBLEM?
  • 1 more comment
  • TOMMYPIMPZ Mar 16, 2008
    CAN IT BE THE MOTHERBOARD OR THE SUBWOOFER?
  • Anonymous Mar 26, 2008
    Front Left Speaker has no sound. Problem RCA Plug on Subwoofer. Logitech suggested for me to purchase another system if my warranty expired after 2 years.
  • TOMMYPIMPZ Mar 28, 2008
    BUT DID YOU TRY PLUGGING IT INTO A CD PLAYER OR IPOD
Ive got the same problem but with my z5500
wonder what it is?
Posted on Mar 25, 2008
  • 3 Answers
SINCE THERE WAS NO SOUND COMING FROM THE RIGHT SPEAKER I TOOK OUT THE GREEN WIRE THAT GOES BEHIND THE COMPUTER AND PLUG IT INTO A CD PLAYER THAN I NOTICED THAT THE SOUND CARD OF MY COMPUTER WAS NOT FUNCTIONING PROPERLY SO I REPLACED THE SOUND CARD NOW IT WORKS PERFECT.
Posted on Mar 27, 2008
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
New laptop. Hooked up Logitech Z5300 speaker system. Have power, but no sound. Fuse is good and volume is up.
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 19, 2011 | Logitech Z-5300 Computer Speakers
My logitech z-640 speakers arent working and i have no clue why first id like to know where to plug in the plugs in my laptop theres a geen,orange,black cord i have a microphone,headphone and some other...
The different connectors are for 5.1 surround audio, and are for different speakers with your system.
  • The green connector is for your front-right/front-left speakers
  • The black connector is for your rear-left and rear-right speakers
  • The orange plug is for your center speaker.
Most laptops do not have support for 5-speaker audio, so if you want to test each individually, you will need to plug them in one at a time and test playing sounds through them.
Hope this helps,
Dec 17, 2010 | Logitech Z-640 Computer Speakers
I have pluged all speakers but not sound on the front and rear to working when i play test they all working but not when i open a music from windows media player.
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech X-530 Computer Speakers
Logitech z-2300 stop working, there is no sound coming out off the speakers anymore
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 04, 2010 | Logitech Z-2300 Computer Speakers
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
Problem with starting the speakers
Xplode
Good day and happy holidays
you have to look at back of your comp, if you has a 5.1 speaker first, like Creative Audigy, live, or X-FI, then according with the cables, colors, must be, Green . black, according for output sound, see manual for the cables and put at back according.
Nov 27, 2007 | Logitech Z-5300 Computer Speakers
Problems with my Speakers
these speakers come with a 2 year manufacturer warranty. a friend of mine had a similar problem and they just sent him a new set of speakers. try contacting Logitech, maybe you'll get lucky too!
Nov 26, 2006 | Logitech Z-5300 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
283 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
