Water coming out the bottom during wash cycle.
When the wife does laundry, I have water coming out the bottom. I have checked that she is not overloading the tub and still I have water on the floor. this does not happen all the time, and sometimes more water than none on occasion. I have had the washer over twelve years and this is the first problem I have had with it. Any suggestions or ideas?
    Scholar:
  • 178 Answers
Washing machine tubs hold a seal at the transmission. If it is leaking now, the seal is starting to wear out. The explanation of it "SOMETIMES" leaking and not is that the load that is being washed could be off balance causing the seal to wear a lil more. If you look at www.marcone.com under parts, you can see for yourself if it will be worth either trying to fix it, have it repaired, or replace it. I hope for you, the first option because more often than not, it is cheapest.
Good luck
Posted on Mar 16, 2008
6ya staff
SOURCE:
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The conditioner drwaer fills with water after each cycle and the machine leaaks during each cycle
Check for pluged drain to washer ,check fill hoses for tighten fittings and good washer inside. (seal). The conditioner container may have a valve that has gone bad or pluged up. To much conditioner can plug this part up, Should check with a appliance repairman. If this is electrical, he should do the job for safety. Hope this might be of some help.
Jun 02, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Leaking water
Does not sound like a bearing problem. Check to see if water is overflowing the top of the tub during spin cycle (due to spin action) and running down the side of the tub.  Water rising up the side of the tub during spin cycle could also be squirting up through bleach dispenser opening and running down side of tub.
May 30, 2009 | Washing Machines
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 21, 2008 | Washing Machines
Drying cycle - laundry comes out wet!
possibly that drain pump is not pumping out - washer dryers take in water during the dry cycle. check filter
Mar 17, 2007 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
