Hotpoint Aquarius 1100 WD61P (analogue) washer dryer, sparking motor (and stopping)
Dear Experts
Appliance: hotpoint Aquarius 1100 WD61P (analogue) washer dryer.
Problem: Motor sparking and keeps stopping.
1) Does this sound like carbon brushes need renewing?
2) How do I tell what type of motor I have (GDP / FHP)?
3) Do I need to remove the motor to renew the brushes?
4) I am trying to remove the motor and need to stop the whole lot moving to undo the bolts.
Any advice would be appreciated.
Thanks
Cliff
  • Zebe Mar 17, 2008
    Thanks for your response.
    I may have not been clear enough in my no: 4 ?
    How do I stop the motor etc moving so I can undo the tight Motor bolts?
    Thanks again
  • 871 Answers
You seem to know what your doing. yes you do have to remove the motor in order to remove those carbon brushes, while your at it, you can also adjust the screwing/bearings of the bolts to hinder the machine from moving a lot.
Posted on Mar 17, 2008
    Guru:
  • 1,894 Answers
Yes u need to change the brush
  • 1 more comment
  • dewan nafees ahmed Mar 17, 2008
    2) by FHP
    3) depending on your model how it is arranged. better to remove fully
    4) yes please move on
    also check if if there is any burn in windings.
    if it has been burnt means then u will end up replacing the whole motor.
    thank you sir.
    for that if you have someone to help it will be nice sir.
    that is the way
SOURCE:
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a Hotpoint Aquarius 1100 washer dryer and think the filter might be blocked but I cannot locate the filter to check it. Any ideas?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the plasic filter inside hose..
Also check the pump for a blockage as well.
Thisn should solve your problem.
Dec 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
How to get access to door interlock mechanism?
WHAT YOU HAVE TODO TO GET THE FRONT OFF IS TAKE OUT THE SOAP DRAWER COMPLETELY THERE IS FOUR PHILLIPS SCEWS TAKE THEM ALL OUT THAN TAKE THE TWO KNOBS OFF THAN LIFT UP THE PANEL SLOWLY WATCH THE WIRES THAN UNSCREW THE THREE SCREWS ACCROSS THE TOP OF THE FRONT PANEL AND THE THREE ALONG THE BOTTOM YOU SHOULD NOT HAVE TO TAKE OFF THE RUBBER TO GAIN TO THE DOOR SWITCH
Apr 20, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
260 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
