Question about Le Chef Electric Shabbos Hot Water Pot-Free Electric Kettle
Electric hot water pot is not pumping water
Water comes out very slowly or not at all--pump doesn't seem to be working properly
  • 1 more comment
  • Anonymous Apr 01, 2008
    same thing
  • Anonymous Aug 14, 2008
    do you know where i can get one or get in touch with le chef?
    thanks
  • sueschwab Mar 08, 2009
    the pump doesnt pump out water fast enough.
Your pumping mechanism is broken you need a new plastic piece inside
Posted on May 21, 2008
    New Friend:
Yes Im referring to sueschwab. Water does not flow easily-- have to keep pumping till wather flows but lately not much water comes out of the urn. Is there a way to know what causes the problem? Will I be able to get it before Friday? And how much will that be?
Posted on Aug 29, 2010
SOURCE:
Whirlpool awm 1200/1
check the pump to see if anything is clogged in there or you could have a bad pump,open the door and look around the opening and you'll see the full model number.also if it stops at the rinse cycle does it fill with water and the water is in there but doesn't drain or are the clothes just sitting there wet,because when in rinse the machine just uses cold water and if the valve is clogged or filling slowly the washer will stop after like 6 minutes,does any error codes come up?you can try to start the washer just on cold water and see if the water fills slowly or if it comes in normally,if it comes in slow most likely that will be your problem,if it is the pump you can get a shop vac and suck out the water from the drain hose,get it as close to the floor as you can and it will work better,then remove the center part of the pump,the clean out and see if it's filled with stuff,turn it slowly,when water comes out vac it up with shop vac until it stops.hope this helps you out.
Feb 10, 2018 | Washing Machines
Drain pump isn't working properly or mystery clog
I would replace the drain pump if you are sure there are no obstructions to the water flow.
May 19, 2017 | Washing Machines
On my wet saw, model ws730 the water doesn't come down right so the blade stays dry
Readjust the water line so the blade stays wet at all times. If it is used dry that can cause the blade to get hot and warp it.
I assume that the water pumps is working properly. If not check the pump and the line so that you have a strang stream.
Jul 01, 2011 | Home
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Pool of water in the drum if I let the clothes sit.
this is a very comon problem, not really witht the machine though. well i guess it is now.
you have debris / change / other stuff.... lodged into the pump
remove the lower access panel, disconnect power, there is a screw out portion on the pump, nail catcher. remove it and catch all water that comes out with a towl. unscrew it slowly to allow the water to slowly come out, or it will make a mess.
the clamp that secures the drain boot to the tub, loosten it and remove. use a large towl to catch the watter that comes out.
remove the spring clamp from the drain hose and remove the drain hose. again use a large towl to catch water. disconnect pump power supply and remove the screws that secure it to the washer, remove pump.
clear all debris from the pump and check to see if anything has damaged any impellars in the pump. do this with your finger.
clean out the rubber boot as well.
reasemble in reverse order.
before the access panel is put back, start the machine and visually check for leaks. if it leaks reset the rubber and clamp where it is leaking.
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine failing to drain
From your description, I would say that the pump impellor is slipping, and the only solution would be to fit a new pump.
Plz rate my suddestion.
Thankyou.
Jan 21, 2009 | Washing Machines
Kitchen Appliances - Others Logo
1,140 people viewed this question
Top Le Chef Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Le Chef Kitchen Appliances - Other Expert? Answer questions, earn points and help others
