Question about Brother HL 1440 Laser Printer
Laser printer error
When i print an excel work sheet the last column has a few partially empty numbers
    New Friend:
  • 159 Answers
First you most insure where is the problem by diagnostic it
reinstall the printer driver
be sure that the excel application work properly by tray to print in another printer
Posted on Mar 27, 2008
SOURCE:
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
Jun 01, 2011 | Canon MF8350Cdn AllInOne Laser Printer
My problem with printing concerns HP laserjet P2055D and excel sheets. When I try to print an excel sheet with table or tables, the pinting result is that the colums where I have used summary function, in...
I had this problem today too. What I did to fix it was to change the printer driver from the UDP 5.1 PCL5 to UDP 5.1 PCL6. It looks like this printer works better using a PCL6 driver.
Sep 02, 2010 | HP Office Equipment & Supplies
My printer does no print for excel file
Hello kushivijay1
Try this.
Open a new excel worksheet and type in Just one or two words or numbers and try to print that sheet. Make sure the correct printer is selected - that is if you have other printers in the list shown in the printer menu- also the correct paper is selected.
If this test is successful, then you have to examine the other excel files which failed to print. Chances are you have the wrong printer selected.
Good luck
luciana44
Feb 25, 2010 | Samsung ML 1710 Laser Printer
When i print a PDFdocument made as an excel sheet , i mean with chart ,all that's writed inside is not printed. On Printed sheet you can just see an empty schedule. thanks
Why not convert the PDF to Excel and then print the Excel Spreadsheet? Nearly everybody know how to use excel and print the contents.
You can try AnyBizSoft PDF to Excel Converter which can help you transfer the tables of PDF into Excel as the original format. All the charts and data will be preserved.
Have a try and hope it helps.
Jul 19, 2009 | HP Photosmart C5280 InkJet Printer
How do you print envelopes?
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007. From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam, no printing, constant error
you can Visit the Konica Printer Knowledge base, which explains on a .pdf and with a video, how to clear the basic fuser roller jam with a piece of card.,no printing,etc click the link and put in your product type that wil take to faq page youll see the issue and solution elaborated
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/start
and work your way through the links.hope this helps
Oct 02, 2008 | Konica Minolta magicolor 2400 Laser...
Printing a report
IS IT THROUGH EXCEL THAT YOU WANT TO TAKE THE PRINTOUT FROM? YES - OPEN A FRESH EXCEL SHEET. COPY AND PASTE EVERYTHING INTO THE NEW SHEET. TRY TAKING A PRINTOUT. YES - GOOD. NO - UNINSTALL AND REINSTALL MS OFFICE TRY ANOTHER PRINTOUT. YES - GOOD NO - CONTACT MICROSOFT VENDOR. NOTE : NO PRINTER DISQUALIFIES ANY MS DOCUMENT.THUS ERROR FROM MS VENDOR.
Sep 17, 2007 | HP Deskjet F340 All-In-One Printer
Brother HL 1440 Laser Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
