Question about Nikon D80 Digital Camera with 18-135mm Lens
D 80, controling shutter speed
Camera would not allow me to change shutter speed above 200 when flash is activated. It just freeze at 200 shutter speed but it allows me to change shutter speed when the flash is off.
can anyone advise me on this please.
The D80's falsh sync speed is only 1/200th of a second. w/ flash off you can max the shutter speed w/o problem.
Posted on Mar 25, 2008
    Guru:
  • 377 Answers
Dear hydet
use 'Program Shift'. This will change the values for both aperture & exposure, but keep the overal exposure value correct. Eg if the standard values are 1/60th of a second at f5.6, then rotating the dial in one direction will change the parameters (first) to 1/30th & f8, etc, and turning it in the other direction will change them to 1/125th & f4.
oke, post in me back
thx
cropp
Posted on Mar 16, 2008
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
Apr 26, 2013 | Canon Speedlite 430EX TTL Flash
My camera flash when on the shatter speed does not increase above 200
The fastest shutter speed with flash is 1/200 of a second. Due to the design of the shutter, the entire frame is not exposed at faster speeds. See the box "Shutter Speeds Available with the Built-in Flash" in the "Flash Mode" section of the manual (page 70 in my copy).
Apr 08, 2013 | Nikon D3100 Digital Camera
I have a D60 and when using my new lighting kit if the aperture is faster than1/200 it creates a blackout across part of the image due to the mirror. Any solutions?
It's not the aperture, it's the shutter speed. It's also not the mirror, but the shutter.
The camera's fastest shutter sync speed is 1/200. You must use a shutter speed no faster than that. Due to the construction of the shutter, the frame is not fully exposed simultaneously at faster speeds and thus part of the image is blacked out.
Using a flash, the amount of light is controlled almost exclusively by the flash; the exposure is controlled by the aperture and the shutter speed is all but irrelevant.
Feb 15, 2013 | Nikon D60 Digital Camera
Cant set shutter speed past 200
Is the flash turned on? The camera won't let you set a shutter speed faster than 1/200 when the flash is on.
Dec 08, 2012 | Nikon D3000 Digital Camera
How do I set the Iso and flash
ISO is the sensitivity to light. The lower numbers 80, 100, 200 are the LEAST sensitive (but provide the best looking pictures). Sensitivity has to do with the amount of light needed to properly expose an image. ISO is a part of exposure that works with Aperture (f stop) and shutter speed (in seconds - or fractional seconds). Here's how it looks:
The graphic above shows that varying either of these three values changes the exposure. If you change one by one step, you have to change one of the others by one step to get about the same exposure result. Each of the step values on your camera for the shutter, aperture and ISO is twice as much as the previous value. ISO 1600 is 2x ISO 800, which is 2x ISO 400, and 2x ISO 200 and finally, 2x ISO 100 (some cameras go to ISO 50 or less!).
The shutter works the same way: 1/1000 is 2x faster than 1/500, and 2x 1/125, and 2x 1/60, and 2 x 1/30, etc. These are easy to see the how each is twice as much as the other.
Finally, the aperture. Each "f stop" allows 2x as much light as the previous value. f2 lets 2x as much light as f2.8, which lets in 2x as much as f4, etc. I know the number don't double like you would expect, and the smaller numbers allow more light (you'd think it was the other way around) - but it's because we're talking about a circular lenses and it has to do with how we calculate area of a circle (3.14 x R squared). It may be easier to recall small numbers = equal large openings by thinking of f numbers with a "1/" over them - like this: 1/f1.4, or 1/f2, 1/f2.8, etc. Here's a chart that shows how aperture and shutter speed work together at one ISO setting.
Read them across, the top line shows that 1/250 @ f1.4 is the SAME as 1/125 @ f2.0, which is also the SAME as shooting 1/60 @ 2.8, etc. If you were to increase the by one step, the shutter speeds would increase by a factor of two. Twice as much light by opening the aperture by a single stop means you must halve the exposure time or halve the ISO value. Likewise, if it's too dark to get a decent picture; increase exposure time or ISO value to capture enough light.
Assume a properly exposed picture requires 1/30 of a second at f5.6 with ISO 200. If the camera was increased by one step to ISO 400, you can take the picture a f5.6 still but in 1/60 sec - greatly reducing the chance of blur from holding the camera in you hand. You could even go up one more step to ISO 400 and shoot in 1/125 sec, which would reduce the blur even more. Fast shutter speeds reduce the "camera shake" and stop motion in sports photography - or other moving objects. If you had the camera set up on a tripod, you could dial the ISO down to ISO 100 and shoot at 1/30 of a sec at f5.6. If your lens can open up to f4, you can shoot in half the time because the lens is letting in twice the light. Some point and shoot cameras don't allow changing f stops or even shutter speeds - so all you can do it raise and lower ISO.
Which camera and flash do you have?
May 23, 2011 | Cameras
How can I use Metz 45 CL-1 with Nikon D3000 and what should be my setting on Flash and on Camera
First you need a hotshoe adapter to connect flash Sync cable to camera. You have to pay your attention about the following settings. Set the same ISO speed on flash gun and camera.( 100 or 200) White balance to Auto or Flash on camera. Mode dial to M (manual) and shutter speed to 1/200 or slower on camera. Aperture setting to 5.6 or 8 (both on camera and on flash) Now take some trial photos and check on the LCD display and histogram and do fine tuning to your exposure. Change the aperture value on camera to control the exposure of flash as well as the ambient light Change the shutter speed to control the exposure of ambient light. (!/200 or slower speed) I hope you got the solution to your problem. I also have the same set of equipments to do my photography.
H.D.Shirantha.
Sep 10, 2010 | Metz 45 CL-1 Flash
Can't control shutter speed
Well you can get the Canon Battery Grip For EOS-40D/30D/20D Model# BG-E2N, which has a separate set of controls including the wheel. OEM is about $170 Chinese clones $80. The camera body will probably sell for about $200 as is on eBay.
Nov 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Shutter speed won't go above 200
I have two possible solutions:
First, are you shooting with the flash up or an external flash connected to it? If so, the camera likely needs to synchronize at 1/200 or slower otherwise it won't be able to take a full photo. As a safety feature to prevent that, many new cameras just restrict the ability to pick a faster shutter speed.
Second, if its not related to the flash, it might be related to the mode you are using. Turn the camera off the automatic modes and put it on an all manual setting. Change the ISO to 400 or so, got outside and aim up at the day's sky, put it on manual mode and then adjust the shutter speed. Open up the aperture on your lens all the way (turn it to the smallest number). Now adjust the shutter speeds. It should be able to go past 200 now.
Nov 25, 2008 | Canon EOS Rebel G 35mm SLR Camera
Tips for Canon A560
You can select the shutter speed in the following range
Shutter speed 15-1/2000 sec
ISO sensitivity • Auto
• ISO 80
• ISO 100
• ISO 200
• ISO 400
• ISO 800
• ISO 1600
Thanks
proton
Oct 11, 2008 | Canon PowerShot A560 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
