Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Phillips DPTV335 colors out of alignment
On my Phillips DPTV335 HD ready TV, the red blue & green are out of alignment & it looks like the old 3d colors. I've tried adjusting the coverage & multipoint coverage, but it appears the TV is so far out of alignment on the red that this method does not get it back into spec. I also reset TV to factory settings & the red is still way off. In addidion to this problem, the picture is out of "keystone" in some areas. The view is curved & looks as if it were "wrapped around a fishbowl", kind of like when you adjust a CRT computer monitor. If anyone knows how to fix this or what part needs to be replaced, please help. My only other options are to buy a new TV or have a company repair both of which will cost hundreds of dollars. Thanks !!!
  • 2 more comments
  • panthers95 Mar 17, 2008
    where can i buy the colors bulbs
  • Anonymous Mar 18, 2008
    my converge red will move vertically but not horizontally
  • Anonymous Aug 27, 2008
    red convergence out of align, center adust up and down, but outsides were it is way off adjustes horizontal but not vertically. blue convg is fine.
  • ssandova Sep 14, 2008
    I have a Philips 60 inch TV with the same problem. The model number on my TV is 60PP9292/17F. Does any body know what I need to fix the problem?
  • Philips Master
  • 8,617 Answers
You need 2 Convergence ICs STK392-120 you can get them at this link and they provide free step by step instructions with free tech support so you can do the repairs yourself.
http://servicemanuals.vstore.ca/
Posted on Apr 05, 2008
I have an phillips dptv 33 O the red blue & green are out of alignment
The tv have a problems known a convergence picture problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergece ICS and some or all of resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 11, 2011 | Philips 55PW9363 55" Rear Projection...
Color convergence lines not aligned
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 02, 2011 | Hitachi 46F500 46" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
Blue & yellow stripe on bottom of screen at first now red and green like 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 08, 2010 | Philips 60PP9202 60" Rear Projection...
The color is way off on the tv. It also looks curved, like if there are words on the tv they go up at an angle toward the edges of the tv. When you try to align the color on the tv you can get the center...
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Philips 55pw9363
The site will send you the instructions to replace the ICs and the tech who is assigned to you will help you out with any questions that you need, also if you ask your tech he will more than likely send you the e-book called understanding basic electronics. The tech will walk you through the repair.That site also has the full 2000 plus page complete service manual for the entire series HDTVs that you can order and recieve in an email if you would like to order one that has a lot of info on television stand by and start up power supplies and how to trouble shoot and etc. I am not aware of any online TV repair courses but then again when you hear from your tech ask him as we go the extra distance with our customers. You may end up getting me as your support tech as I am one of the 4 techs that do the online support for them.
Apr 12, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 looks 3d
You need to replace both convergence ICs they are STK392-120 this is an easy repair that you can do yourself and save yourself around 400.00 for about 45 minutes work. You can order the new ICs at the following link and they provide free installation instructions with pictures and also free online support with a support tech while you do the repair. I am one of their support techs. You would also want to order at least 4 convergence resistors and they send the proper ones for your model as often a couple resistors go. Your model uses 6.8ohm 2watt 5% metal film resistors. So to recap you will need (2) STK392-120 Convergence ICs and (4) Convergence ICs . very inexspensive repair if you do it yourself. here is the link.
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
1,389 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
