Back to:
Tags:
Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cybershot DSC-H7 - can not change flash...
posted by amberlynn82 on Mar 16, 2008
I have the camera listed above and have tried to change the flash settings in every single mode that there is available, however, it still tells me that flash settings can not be changed. The only mode the flash will work in is twilight portrait, and even then it has a certain setting it used and I cant change it. Any ideas?
Comment by amberlynn82, posted on Apr 21, 2008
Thank you all for your suggestions. And thank you very much Nathan, because it was in fact on burst mode. Thank you all again for trying to help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 03, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you go into the camera settings; look under rec mode. It might be in "burst" mode. Flash will only work while in "normal" mode.
~Nathan~
Rating Locked! (?) amberlynn82 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony Cybershot DSC-H7 - can not change flash settings:
I don't want to Accept this solution
Solution #2
posted on Apr 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Another solution:
Turn camera on
Move slide to center position (still image)
Press Menue
Press controll button left until you arrive at (camera) settings
Press control button down to select (Auto)
Press Menue button
This should remedy "loss of flash" problem.
Good Luck,
Dan
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Mar 16, 2008
Not Rated (0)
cropp
Rank:Guru Guru
Rating: 86%, 228 votes
hi dear
i think you have to visit this site
http://www.dpreview.com/reviews/sonyh7/page3.asp
i hope it solve your problem
oke, post in me back
thx
cropp
Thank You!
Can you Help with these Digital Cameras problems?
can not take pictures as there is no image on screen its...
The problem which I faced with is an adapter ring being...
The little platic things that hold the door to the battery...
my camera got wet, send it to fix but the guy just kept it...
When you put memory stick in just does not work.
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
