Question about EliteGroup P4M800-M7 Motherboard
After Bios Upgrade Computer don't Boot
After Bios Upgrade in P4M800-M7 V1.0 don't can boot.
File used: E052211.ROM
I did a reboot after upgrade, the error message appeared to date. Common after an upgrade.
I was the setup and pressed the key F9 (default configuration) and F10 (save and exit) after that the screen is black and not boot and dont beeps.
To go back to work I did a reset the battery. I changed the memory and back to work, but the system crash and led of HD was red.
Appears problem of frequency in DRAM but what to do?
There is some bios to downgrade? If yes where?
  • 2 more comments
  • JohnFelix777 Mar 17, 2008
    Hello Iqbal, very thanks, but...
    When used E052211.ROM and change BIOS setting Advanced Setup -> DRAM driving item to High, the system do boot but the windows was colorless and in any minutes total crash.
    Using your solution don't boot. What can to do? Any configuration in setup?
    Very Thanks.
    Hello Iqbal, very thanks, bus
    Using the E052211.ROM and change BIOS setting Advanced Setup -> DRAM driving item to High can boot, but windows was colorless and crach in any minutes.
    When test your soluction don't boot. Any configuration to do?
    Very Thanks.
    Hello Iqbal,
    I did your soluction fix and change memory for DDR 333, and fix my problem. But loose my memory DDR 400.
    No the memory DDR 400 isnt currepted, it's in other computer now.
  • 655 Answers
Hmmmm you have currepted your DRAM, no problem try this file i think it will fix your problem.
Click here to download.
and try to write.
Thanks
Iqbal
Posted on Mar 16, 2008
I try update my bio on my ao0751h netbook acer, and doesn't successfully, now my netbook doesn't turn on. How i recovery a bios?
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive.If you have a PCI video card,you won't see anything on the screen because the boot-block BIOs only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
  1. Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufactures send them for free.
  2. Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or Bios World
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
  1. Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
  2. After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
  3. Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
  4. Flash an appropriate BIOS to the corrupt BIOS and reboot.
Solution 4: (for Intel motherboards)
  1. Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
  2. Install the bootable upgrade diskette into drive A:
  3. Reboot the system
  4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
  5. Turn the system off
  6. Change the Flash Recovery jumper back to the default position
  7. Leave the upgrade floppy in drive A: and turn the system on
  8. Continue with the original upgrade
Feb 03, 2010 | Computers & Internet
Emachines notebook m5310 corrupted bios recovery
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at ftp://ftp.mrbios.com
Reboot the system
Turn the system off
Oct 14, 2009 | Computers & Internet
Can not boot dell 6650 from external dvd
Have you checked boot device options....from BIOS
Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
Insert Boot media or DVD-Win2003, to DVD-ROM device..
reboot Server, try now
If still issue.. Check to boot Server using some other media..
if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
Oct 06, 2009 | Dell PowerEdge 6650 Server
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Bios upgrade
You can use Winflash to upgrade the motherboard BIOS or during boot using text or character driven interface . These utilities can be downloaded free of cost from the mobo manufacturer website. BUT MIND YOU IF YOU DO NOT FEEL CONFIDENT ENOUGH OR NOT SURE OF THIS PLEASE DO NOT TRY THIS AS ANY ERROR IN THE PROCESS OF UPGRADING MOTHERBOARD BIOS WILL RENDER THE THE MOTHERBOARD USELESS. An 8x AGP PRO Card should work without hitches on tis mobo
Apr 03, 2008 | EliteGroup Intel Pentium 4 Processor...
1801 Microcode Patch Error
I bought a Compaq Computer, 2.0Ghz, 256MB, 20GB for my College project. When i put the power on, it restarts almost immediately (so many times repeatedly). Then after such reboots, it successfully brings a message "1801 - Microcode Patch Error" and a F1-Boot directive.
Mar 20, 2008 | Compaq Evo D500 PC Desktop
After Bios Upgrade P4M800-M7 V1.0 dont Boot
Try and go back to an earlier upgrade as this sounds like it might have hurt your original MASTER BOOT RECORD. If you find one that works quickly copy your MASTER BOOT RECORD and save it.
Mar 17, 2008 | EliteGroup P4M800-M7 Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
125 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
