Pioneer PD F506 changer jammed
Pioneer PD F506 changer does not load cd's. I bought this item on ebay, and it was damaged in shipping. the seller refunded me my money, and let me keep the changer. I opened it up to check it, load some cd's, and when pressing the play button, the changer emits a humming sound, then moves to the right 1/2", then back, then shuts down. looks like the changer mechanism is jammed on the inside. any suggestions?
chucky
  • t10sbum Mar 16, 2008
    I have taken the changer off the track to check it, and both motors and drive pulleys appear to be working.
    Scholar:
  • 105 Answers
It is quite possible that one of the drive belts has come off its pulley.
Posted on Mar 16, 2008
6ya staff
SOURCE:
Pioneer 25 disc changer pd-f606 flashing lock how do i get rid of ?
I think it is a parental lock feature that should be in the menu system to turn off.
Sep 17, 2012 | Pioneer PD-F606 25-Disc CD Changer
Pioneer PD-M551 cd changer won't play cds 2 thru 6.
Thank you, Mark Z! My Pioneer PD-M551 would just stop reading the CD, usually near the end of the 4th or 5th disk, and then sometimes it wouldn't read any disks or maybe only the first one or two. I observed that the white ribbon cable was most contorted near near the end of the 4th through 6th disk (also discovered the disks are read proceeding from the center outward, unlike vinyl records). I unfolded the ribbon, massaged it and left it loose and unfolded and that fixed it (at least, temporarily). The PNP-1343 ribbon cable from Pioneer costs $11 but with shipping and handling it is over $30 so I haven't bought it yet.
Jan 28, 2012 | Pioneer Audio Players & Recorders
My Pioneer PD - F1007 301 Giga Changer is jammed and the CD carousel will not rotate.
if you email me [email protected] (put pioneer pdf in title) will sed you service manual with realignment instructions plus disassembley instructions regards yammandan
Aug 19, 2010 | Pioneer PD-F1007 301-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
use krazy glue to get the arm glued with the cd port or use electrical tape.
Jul 14, 2009 | Pioneer PD-F507 25-Disc CD Changer
Pioneer PD-F506
Then it may be a registration problem - the changer has to know what position the tray is in so that it can play the correct cd - often there is a foil connector that gets damaged or an opto coupler that goes faulty.
Mar 16, 2008 | Audio Players & Recorders
My Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
222 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
