Powers on will not change channels or video inputs
Powers on stuck on channel 38 will not change to video inputs,remote turns it on and off nothing else,has great picture still.
  • seattlefelix Dec 19, 2008
    my tv will power on and off both manually or with the remote that came with the set but it will not change channels either at the tv manually or with the remote.  Just happened after a night of regular tv watching.  Any ideas?
  • 85 Answers
Is your remote programmed properly? If it is a universal remote, try setting it to one of the different codes for your brand. Sometimes the power and mute buttons and things like that are the same for all different types of a brand, yet all of the channel and volume things are different. If it's the remote that came with the TV, then I would try to get a replacement, as it could be faulty. Hopefully this problem is with the remote, and not the TV. Find if this is the case by using the volume/channel buttons on the TV itself. If they work, then you can be reasurred you don't have to call the TV repairman, and you will probably be able to fix this problem yourself.
Posted on Mar 16, 2008
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
