Question about Refrigerators
Water will not dispense from door. ice machine works. it is a gold edition
    President:
  • Refrigerators Master
  • 2,651 Answers
Listen closely when depressing the arm can you hear a switch being activated?? does the light come on when arm is depressed, if no to eitherr sounds like a faulty microswitch behind the dispenser if you do hear hte switch adn the light does come on then go to the back of unit and disconnect the plastic tubing leading to the dispenser the larger of the 2 plastichoses, place a cup under hte valve and depress the arm now(this way we eleminate the frozen of clogged hose. if still no water id say you have abad water valve( whoile back there you can also disconnect the wire leading to the water valve solenoid and check that for proper 110v when depressed.) if you got voltage andstill no water you def have a bad valve
Posted on Mar 16, 2008
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Whirlpool GS6SHAXMB00 ice dispenser not working
remove the ice bin close door and push for ice and hear if the motor working if motor not could be door switch if motor working is the solideo valve
Mar 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ice dispenser not working
RECHECK THE CONNECTIONS AT THE UPPER DOOR HINGE WHERE THE ELECTRICAL WAS DISCONNECTED. MAKE SURE ALL THE PINS ARE STAYING IN THE PLUG WHEN YOU CONNECT THEM TOGETHER.
ALSO, BE SURE THE ICE BIN IS PROPERLY INSTALLED.
Apr 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
