Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blue flickering light, no audio
I've removed the back panel on the TV in order to access the power supply and check the capacitors. How do I remove the power supply? Is it all one unit? Does the entire bottom left section come out together? I'd appreciate any help. After reading where others had the same problem, I'd like to check the capacitors and see if that's a problem before taking to a technician.
    Problem Solver:
  • 3 Answers
I have a rca d52w19 had no sound or picture.green light on power button would flash 3 times then stop i just replaced the 2200f 16v green cap on power board (if the top has popped up its bad)now i get picture and sound.but i have the Blue flickering light.let me know if you find out what is causing this.
Posted on Mar 23, 2008
  • bubba Apr 15, 2008
    ? would putting capacitor in backwards cause the light to blink?
  • Mitsubishi Master
  • 8,617 Answers
You will need the service manual in order to get that chassis out. once out it is an easy repair to replace the capacitors yourself. I just did one the other day. You will need the service manual for sure it will save you alot of money on repairs. heres a link where you can get the factory service manual.
http://servicemanuals.vstore.ca/
Posted on Mar 19, 2008
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
My tv just popped shot blue sparks and smoked a little? Power supply? No power light.
Yes. It must be from its main power supply regulator section. Might be due to burned backlight inverter transformer at the back light inverter board. It is an other chance. Check it.
Jun 06, 2012 | Philips 42PFL5332D 42 in. LCD Television
We turned our tv off for like 3 hours went to turn back on and red light turned blue like it was going turn on but screen stayed black then speaker made a noise and light went back to red. It did that 28...
The problem is the power supply of your television.The power supply have abnormal voltage supply output cause of leaked capacitor.The leak capacitor have bulging tops, so that you can identify the leak capacitor. Just remove the cover and find the power supply and replace new capacitor with same polarity.Hope it will help you.Thanks..
Sep 04, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I have a 32 inch wharfedale, approx 3 years old, it keeps switching off, sometimes every few minutes but the blue light stays on..This has been happening for a long time but I've been told the cost of...
This trouble caused by weak dc output voltage. Try to check your power supply it is located at back of your tv, try to remove the back cover of your tv and follow the ac cord there you will see the power supply then try to observed the capacitors if their is a swollen or leaky capacitors you will notice it that the bottom of the capacitor has a wet mark or an oil spill if you notice something like that, try to replace it with the same value. But be very careful,observe the polarity of the capacitor.
Jun 07, 2011 | Televison & Video
WHEN THE TV IS PLUGGED IN AND TURNED ON IT FLICKERS IS THIS A POWER SUPPLY ISSUE AND IF SO WHAT IS THE SERIAL FOR THE POWER SUPPLY
The flickering you describe is most certainly a bad capacitor in the power supply. find a hobbiest or TV tech to do this for you. These TVs require lots of patience to remove the back cover and removing the power supplies. Good luck and thanks for asking.
Dec 19, 2010 | Audiovox fpe 3207 32 in. LCD Television
My matsui m32lw508 will not switch on just flickers then the standby light comes on.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care .......
Oct 04, 2010 | Televison & Video
How do I access the circuit board on the Apex LD1919?
All the components are screwed to the back of the cabinet. Once the back screws are removed, the front bezel snaps off. (Not easily, but take courage and try.) Release a connector in a set of leads to the pilot light panel to get enough slack to lay the bezel flat. The LCD panel then removes with seven silver screws (one is a ground lead). Move it to the side, and the power supply board is accessible. Two connectors and four screws, and it comes out.
Jul 02, 2009 | Apex Digital LD1919 19 in. LCD TV
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
Vx800 flickers when cold
I have repaired several Viewsonic VX800 monitors. The symptoms include a power light that flickers or flashed on and off or a screen that flashes on briefly or stays off. The problem is bad electrolytic capacitors on the power supply board. These bad capacitors do not look bad and do not swell but they do develop a high ESR (Equivalent Series Resistance). You need a ESR meter to check them. But if you have these problems, you should assume the capacitors are bad and just go ahead and replace them.
First you must open the monitor and gain access to the power supply board.
1. Remove the stand: It is held with 6 screws on the back. Also on the back are 2 black screws that must also be removed.
2. Remove the button bar from the front, bottom: It is pried off. This will expose the 2 screws holding the front plastic bezel.
3. Remove the silver plastic bezel from the front: First remove the 2 screws holding it, then you can pry the rest off. This will expose the 2 screws holding the screen to the plastic back.
4. Remove the screen and electronics from the plastic back: Remove the 2 screws holding it. The 2 speakers are glued to the plastic case. Cut the glue with a knife. The screen and electronics and speakers should lift out of the plastic back.
5. Remove the metal cover to expose the electronics: There are 2 screws holding the VGA connector and 2 screws holding the DMI connector. There are 9 screws holding the cover. These must all be removed. There is a black plastic sheet glued to the lower edge of the cover. It must be lifted. The cover should now come off.
6. Replace the bad capacitors. The power supply and signal processor are on the same board. It is marked VG800-2. The bad capacitors are surfaced mounted 100UF 25V. The bad capacitors are CM16, CM17, CM2 and CM165. The two most critical are CM16 and CM17, but they all read high ESR, so I just replace them all as long as I have them exposed.
Reassemble in reverse order.
Oct 18, 2007 | ViewSonic VX800 18" Flat Panel LCD Monitor
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
