Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Lamp meter on Panasonic PT-40LC12 ?
How do you reset the lamp meter on the PT-40LC12 ?
  • Anonymous Mar 23, 2014
    the manual said to refer to instructions enclosed with lamp unit Part LA1001 but found nothing about reset. Also no instructions in manual
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Posted on May 28, 2008
Thank you to the gentleman whom posted this question and to all those whom gave a suggestion.
I solved my Panasonic PT-40LC12 T.V.'s problem.
I installed the ebay-bought lamp in the old housing. Installed the housing. Installed the cover plate and then the cover trim. T.V. turned on.
I then cleared the display with the recall button on the remote. I used the T.V.'s "vol -" button to turn the sound all the way down. I pushed and held the "vol -" button again and one second later pushed and held the "PP/Play" button. The volume meter disappeared and a display saying "The lamp meter has been reset to 0" then appeared. The problem's resolved. Thank you.
Posted on Dec 30, 2008
  • jedianiel Nov 01, 2010
    I was going crazy trying to figure out how to reset. Your method worked. THANKS!
There is no split play botton on remote but I tried each of them individually with out success. Any other options?
Drday@prodigy.net
Posted on Apr 27, 2008
I purchased a new bulp from bluestar-online.com and the following directions came with it:
1. Push the power button to turn on the TV.
2. While pressing and holding down VOL- button on the TV, press and hod down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
I have replaced the bulb before and did reset the lamp meter but for some reason it is not working this time. This time I purchased the lamp only and installed it in the old housing. The instructions came with the bulb. Ended up saving $150. The tv comes on fine but for some reason the lamp meter won't reset? There is not a "Split play" button on the remote. I will play around and see if I can get it to go.
Posted on Mar 26, 2008
You have to have a Panasonic remote (one that came with the tv, or a similar model), and if it doesn't have the PIP button (or Split-Screen button), then you will have to use the '0' (zero) button.
Power on the tv, (and wait for the lamp replacement text, and press ok or enter or whatever it tells you to make that go away.) then press and hold the zero button on the REMOTE, and AT THE SAME TIME, press and hold the 'vol -' (volume down) button on the TV.
Zero button on remote AND
Volume button on TV AT THE SAME TIME.
This worked for my PT52LCX16 ( PT-52LCX16 ) which came with a remote without the PIP button.
Posted on Oct 11, 2008
    Problem Solver:
  • 16 Answers
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Posted on May 22, 2008
2 Suggested Answers
  • 32 Answers
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Posted on Jan 20, 2010
Testimonial: "Thank you so much for your help. Worked like a charm!"
How do I reset the Panasonic PT-43LC14 projection TV's lamp hour meter
Go to "Service Mode Map" by pressing the "Volume down" button key on the front panel and "TV/Video" button key on the remote control at the same time and hold it for more than 5 seconds. You can now reset/change the value of lamp operation time.
Jdvillanueva
Sep 21, 2011 | Panasonic PT-40LC12 40" Rear Projection...
How do I reset the Panasonic PT-40LC12 projection TV's lamp hour meter. What is the command?
Jan 20, 2010 | Panasonic PT-40LC12 40" Rear Projection...
I just replaced the lamp on my Panasonic PT-40LC12 TV. How do I reset the timer and make the red light go off?
what you need to do is have your remote handy and go up to the tv. Hold volume down the tv and pip on the remote for 5 seconds.
Dec 08, 2009 | Panasonic PT-40LC12 40 in. LCD Television
Panasonic pt 40lc12
THIS TV HAS ONLY ONE LAMP. HAVE YOU DOUBLE CHECKED THE LAMP ASSESS DOOR BECAUSE IF IT IS NOT SECURE, YOU MAY HAVE ISSUES
Jul 07, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic hdtv
Pull the left front panel off of the unit and you will find the lamp door behind that panel. It is very simple to pull the lamp and most times you can even see the element in the lamp has blown. You can easily buy and install the lamp yourself.
Mar 19, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Ballast problem on PT-40LC12
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
1,963 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
