Question about Sewing Machines
Can't get the bobbin thread to raise
I have tried everything short of standing on my head and still can't
get the bobbin thread to raise. I have changed my needle, adjusted the
top thread tension both ways, re-threaded the machine many times,
changed bobbins and rethreaded it twice, and read the book cover to cover.
any suggestions would be very helpful. I have a brand new (only used
once before now) Singer Inspiration 4220/4228. please help asap!!!!
  • kater2345 Mar 17, 2008
    thanks for the advice!!
    I finally got the bobbin thread to raise by pressing the foot peddle for about a second that finally produced the loop for me and allowed me to finish what I was working on. I will call Singer and ask them for suggestions and where I can take my brand new (received it as a Christmas gift from my in-laws) machine.
    Again Thanks for the advice!!
  • MoodsOfMe May 09, 2008
    i just opened my new singer futra CE-100 for the first time last night... i had received it for christmas 06... i know i should of used it by now but i was living in a small apartment with no room or extra money to spend... i just moved back home and wanted to start on my first project.  i read the instruction,  but i had also had classes on sewing so i am not dumb when it comes to sewing.... Anyways i thread and rethread my machine i even redid my bobbin... and the needle will not grab my bobbin thread.... I'm going crazy... the worst thing is the warranty is not good it took me almost 3 years to open it... why me...
I have a singer inspiration my needle is hitting the bobbin case and needle keeps on breaking not picking up the thread . how can i fix the bobbin case. help
Posted on Jan 08, 2009
  • Sewing Machines Master
  • 1,388 Answers
Check the flat side of the needle is facing the rear of the machine.....thread needle when needle is at top of its travel....with 100mm/4in excess length
Set top tension to 4
Pull about 75mm/3in of thread thru bobbin case
Rotate handwheel manually one revolution holding needle thread loosely......does it pick up bobbin thread ?
If this still won't pick up, the timing is out, take it back to the Dealer and ask them to restore the setting, as it should not lose timing that easily unless it was marginal leaving the factory, or you have been quite brutal with heavy workload of heavy duty fabrics which you say is not the case..
...items are sold and need to be "fit for their intended purpose" whether new or second hand, with a new item, you have the added protection of a 12 mth warantee....
....phone them to explain your dilemma, what you have done to try to solve it according to manual etc and arrange a time to take it back..
...they will want your good words about them to your friends and that you go back to buy other things over time.
Posted on Mar 16, 2008
    Problem Solver:
  • 5 Answers
Maybe you should try and take the needle out and make sure it is installed correctly or you could make sure that the bobbin case is installed correctly as well, since on this modle it tends to pop out.
Posted on Aug 11, 2009
The tension on the top is out of sync. Don't know what to adjust. Help
Since we don't have a clear picture of what is happening, we can't offer much in the way of advice. Here is something to try:
Remove the top thread from the machine.
Be sure to install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct.
Remove the bobbin and rethread it into the bobbin case and install it in the machine. Make sure the bobbin is turning the correct direction in the bobbin case.
Set the top tension to the midway point (the factory standard tension).
Retest the machine.
HINT: Thread issues appearing under the fabric are usually a top thread problem. Thread issues appearing on top of the fabric are usually bobbin related.
If top thread is showing under the fabric, tighten the top tension.
If bobbin thread is showing on top of the fabric, loosen the top tension.
If problems continue, the bobbin tension may also need to be adjusted. HOWEVER, that is a last resort and a very tricky change to make. Be sure to mark where the tension screw is set BEFORE making any changes to the bobbin tension screw (so you can reverse your changes if it doesn't work).
You can also try changing the type & size of needle and the brand/weight of thread. AVOID old or bargain bin threads. Your needle choice, thread, and fabric should be compatible. Using the wrong needle can cause huge problems with stitching success.
Understanding Thread Tension Threads
Feb 14, 2018 | Sewing Machines
My phone # is ************. How do you adjust the tension on the model JX2517 Brother Sewing machine? I need help right now or I am returning it
Hi, I do hope this link will help you, it shows a step by step process with pictures to assist you further, I do hope this helps....
http://support.brother.com/g/b/sp/faqend.aspx?c=us_ot&lang=en&prod=hf_xr1300eus&faqid=faqh00100034_005
Feb 08, 2018 | Brother Sewing Machines
I have a Seammaster machine Model # 6950. I bought it with now book. How do I adjust the tension on the bobbin?
Here are some instructions regarding tension adjustment. However, before you try changing the bobbin tension, I suspect that it is the top thread creating the mess of thread. REMOVE the top thread from the machine, ALWAYS RAISE the presser foot, and rethread from the beginning.
There are some manuals available for purchase for your machine. Search for Simplicity Seammaster 6950.
Aug 04, 2017 | Sewing Machines
Bobbin thread is jamming machine
it indicates that you have a situation called " bird nesting" and that is a result of the needle thread tension being too loose
needle tension should be tight so that when you pull the thread to thread the needle you have to exert a bit of effort to pull the thread through the tension plates
you can adjust up or down from that feeling
thread thickness affects the tension and needle eye size also affects the tension as a small eye on large thread makes the thread movement hard indicating less tension or a big eye on a small thread affects the tension as the thread slips easily and needs more tension to pull the bobbin thread up to the centre of the material being sewn
Dec 20, 2016 | Brother Sewing Machines
Breaking cotton on top and bobbin
Try loosening the tension for that bobbin
Dec 15, 2015 | Sewing Machines
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
Brother sewing machine xl2600
Don't worry! I'll try my best to help out here. Problem is most likely in bobbin area. Remove bobbin, clean with brush to remove any threads caught in tension discs. Brush the feed dogs (teeth area under your needle plate).Rethread with presser foot in UP position so thread can locate tension slots. I recommend new needle and remember to push it up into needle bar shaft flat side back a's far a's it will go. Tighten needle clamp screw. That press foot must stay raised now while you insert needle And thread it. Tension: Set at 4. Just a very short turn of tension if 4 is not giving desired results. I hope this helps. It's probably very frustrating, I understand, but I know you can remedy this easily. Follow above steps SLOWLY! Jimmy
Apr 03, 2012 | Sewing Machines
The upper thread keeps getting caught under the bobbin casing when sewing. The machine will stich, but when I pull it out there 3 threads pulling out instead of the 2 there should be. I have read the...
Other than your machine being out of time and needing service, following are suggestions to try:
Be sure to use the correct type of needle for the thread and fabric you are sewing, ie sharp, top-stitch, embroidery, universal, or microtex for woven fabrics and ball-point needle for fine knits.
AVOID old or bargain bin thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin case is properly threaded.
Set the top tension to the midway point.
Re-test your machine and tweak the top tension so the top and bobbin threads meet in the middle of the fabric.
If the thread continues to hang up, take your machine for service and adjustment.
Jul 27, 2017 | Brother CS-6000
The bobbin thread is sewing loose stitches and jamming the machine. I have re-threaded everything, brushed out the bobbin casing, changed needles, adjusted thread and bobbin tension, and am stuck and...
Always have the presser foot up when you thead any sewing machine.
Make sure the flat side of the needle shaft is facing to the back of the machine.
Don't do anything to the bobbin tension. Set the top thread tension to what is recommended by the mfg.
Make sure the thread from the bobbin is feeding from the bobbin in the correct direction and through the correct guides.
After inserting the bobbin and threading the machine, lower the needle (hold on to the thread tail) and then raise it by turning the hand wheel by hand to pull up the bobbin thread.
Gently pull the two threads under the presser foot and to the back of the sewing machine before you begin to sew.
Feb 19, 2010 | Singer 3116 Simple
Sewing Machines Logo
1,706 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
