Question about Mitsubishi VS-45607 45" Rear Projection Television
Jumping picture Hi, The picture jumps for about 3 - 4 hours after turning it on, then sometimes goes away completely or jumps slightly
  • Mitsubishi Master
  • 8,617 Answers
Resolder the vertical output IC and the vertical yoke connections on the main PCB
Posted on Apr 06, 2008
I have a 2000 Grand Caravan that will ONLY start with a JUMP ........ the starter clicks and WILL start the VAN the battery is GOOD and new it was checked 2 times by 2 different places ..... the...
it sounds like you may have a bad starter solenoid and the extra voltage from the jumper vehicle is enough to complete the circuit through the solenoid to allow the starter to turn over.sometimes the solenoid contacts get very dirty and can`t complete the circuit on its own without a jump.i think these have a bosch starter system on them and you can replace the contacts only in the solenoid.
Apr 08, 2011 | 2000 Dodge Grand Caravan
When turned on picture is very wavy (can't tell what you are even watching). After a time it becomes clearer until picture eventually returns. Recently, picture is wavy, mores on top, and has a slight...
The problem is from the lamp of the television, it seems to be having some faults, it is gradually getting damaged.
It will start by being wavy until it goes completely blank.
Some lamps go for about $125 or more. Some go for $200.
Take care and Good luck
Oct 23, 2010 | Televison & Video
My 316ti won't start, battery is good as we had it checked out. After a jump start it goes well and then after about 24 hours it won't start again. Thanks
You say it won't start. Does the engine crank over? Or is everything just dead? I once had a car with a faulty solenoid. You could jump start it (extra amps) but on its own sometimes it would not.
Apr 07, 2010 | 2002 BMW 3 Series
Picture jumping
If this jumping is accompanied by a sharp snapping sound, it may be the high voltage circuit discharging to chassis. Leakage can cause the jumping and a discharge can momentarily blank the picture.
If you want to try a 'cleaning cure,' I suggest you pull the plug (not just turn it off) for several hours, preferably overnight. Sets of this size can carry enough static charge to punch a hole through your thumb if you get careless.
Remove the rear housing (shouldn't be more than 6-8 screws) and using a clean paintbrush, and possibly a vacuum to **** up the dust, clean it well and pay special attention to the area around a largish misshapen black plastic object bigger than most anything else and connected to the back of the picture tube via a fairly thick cable.
Dec 09, 2008 | Televison & Video
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DVD/VCR
It means that it is adjusting the sound from mono to hi'fi... probably because the tape is dirty/damaged or (more likely) the unit needs to be seriously cleaned. Try a cleaning tape, and if that doesnt work have a shop clean it.
Sep 20, 2007 | Kenwood DV-5050M Multi-disc DVD Player
Mitsubishi VS-45607 45" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
