Question about SanDisk Sansa E280 MP3 Player
Wont put songs on
I try to download songs onto my sansa e280, when i plug it into my computer it says "connected" as soon as i try to put a song on or if i delete a song it says "writing". that doesnt go away and when i disconnect, the songs i deleted are deleted but the songs i tried to put on arnt there. what do i do
  • Benjamin Patri
    Benjamin Patri May 11, 2010
    Have you tried resetting the player to default and then putting all of the songs back on?
  • 3,037 Answers
Try resetting the player to default is what I would try and make sure the encryption is MSC which I believe is the other option
I hope that our answers help you
Posted on Mar 21, 2008
  • 8,596 Answers
I would wait for the writing message to go away before disconnecting the player - this is the standard message it will give you when you are transferring songs to the player. If it still says writing after 5 minutes (this is assuming you are not trying to load more than 20 songs at once), then you might have a real problem.
Make sure the files you are trying to load do not have DRM encryption on them, and also make sure they are in mp3 or wma format.
If you have Windows Media Player 11:
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Mar 18, 2008
SOURCE:
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Im not sure how to put songs on my mp3
Connect your device to your computer using USB cable. Then go to My Computer. You can see the MP3 Player drive. Just double click it and you can copy and paste there your songs
May 19, 2009 | SanDisk Sansa E280 MP3 Player
My Sansa E260 randomly stopped working
Check and see if the songs you put on the mp3 player are a hidden file Connect to your computer open my computer goto tools on the top of the page folder options click on view Here you will see Hidden files and folder click on do not show hidden files and folders and put a check mark on hide ext....and hide protected Hit apply. Delete any songs you put on the player and start over
Apr 10, 2009 | SanDisk Sansa e260 MP3 Player
Computer doesn't recognize MP3 player -
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
How do I delete duplicate songs from my e280 song list?
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
view-the-downloading-videos-by-sorting-16-1srvjsc4otpwize3cqbthuvm-1-0_1.jpg For more details, check: How to Delete Duplicate Songs
Mar 14, 2009 | SanDisk Sansa E280 MP3 Player
Cant add songs to the Sansa e280
go to settings then go to usb mode then switch the one its not on its only two
Jan 24, 2009 | SanDisk Sansa E280 MP3 Player
Cant seem to get songs to download from Rhapsody
dont use rhapsody... is a scam. get ur songs on limewire and put them on manually.
May 01, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 not working
I had the same issue. Plug the player in your PC. Go to "my computer" right click the Sansa player. Go to Properties and then select the "tools" tab. Run the error check and the disc defragmentation
Mar 25, 2008 | SanDisk Sansa E280 MP3 Player
Cant get songs onto my Sansa e280 player =[
"Refresh database" is a normal message that you will get everytime you unplug the Sansa from the computer - don't worry about that aspect.
If the songs that you have transferred have DRM encryption on them, they may not play right (or at all) on the Sansa.
If you have Windows Media Player 11, I would get the firmware update from the Sansa website AND format the Sansa inside Windows Media Player:
for the firmware,
for the format, http://www.sandisk.com/Retail/DriverDownloads.aspx
Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything and get your player functioning normally.
-Tha Mp3 Doctor
Mar 18, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 wont play downloaded music
The device has 2 modes on it MSC and MTP, if you changed modes and uploaded songs in the other mode, they are only visible on the PC in that mode. But, the PC will show the total amount of free space on the device.
If this is not the issue, I would try formatting your device to remove everything and start over.
You can FORMAT thru My Computer>Device Name (e280)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
You can also add to this question for additional support.
Nov 22, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
