Question about Philips Televison & Video
I have a Phillips DVP3340V/17. My question is can I record a tv progam to a DVD disk or VCR tape ?
No you cannot with just this machine.
Posted on Jan 25, 2009
SOURCE:
Progam phillips RC144 remote for verizon fios
the remotes usually to program combos ...but you may want to try the dvd ...and vcr codes ...as well
May 22, 2010 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
What channel do I set my tv to to watgh a dvd
Mostlt likey 3 or 4.
Please explain how you have it connected so that I can be sure.
What input (connections on back of television) do you have it connected to on the television?
Or if you could explain the colors of your wires.
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
We have a Philips VCR/DVD player DVP3340V/17. According to the manual we have it hooked up correctly but it will not record on VCR or DVD. Help
Here's what's going on with that unit. The DVP3340 records on the vcr side only, not the dvd side. To record on the VCR side, you would have to plug a red, white, and yellow plug from the red, white, and yellow OUT of your cable box to the red, white, and yellow VCR IN of the Philips. The manual, as far as I can see, only shows hookups for playback, not for recording. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | Philips Magnavox DVD/VCR Dual Player
RECORDING
This model DVP3340V is only a DVD player/VCR. You can record to the VCR but not on the DVD.
Apr 19, 2008 | Philips DVP3340V
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
DVP3340V/17 DVD/VCR
Well fbyrd95 goodluck. I have checked out the pages they offer for help. You will need to purchase a cable/satellite box to get the channels routed through the vcr. I received one of these for christmas. It is the sorriest excuse for a vcr/dvd combo I have ever seen. If this is bought as a dvd/vcr combo then I would assume that vcr means that it will record. I do not have the receipt or it would be returned. I will never purchase a philips product.
Jan 03, 2008 | Philips DVP3340V
NO PICTURE OR SOUND ON THE TV
I'm not sure if you've done this yet, but this might work.. goodluck to you... let me know if it helps
Dec 31, 2007 | Philips DVP3340V
Need help
Press VCR source, switch to the correct channel and press the RECORD button.
Oct 31, 2007 | Philips DVP3340V
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Televison & Video Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
