Computer speakers I bought an altec lansing set of speakers for my H.P. computer. I have vista. I hooked them up and they work fine when I play a c.d, but I play a lot of games in various sites, and it doesn't sound right. Why? The speakers are 2 small ones for the left and right,and the big one is just for bass, treble, and volume. Can you help me? Is there something I need to tweak? Buy the way, they used to work fine on all my game sites. The speaker is not that old, and I haven't monkeyed around with it at all. I don't even turn it on when I'm online playing games. I do get really good sound when I listen to videos and live streaming video's. Please help! Bonnie [email protected]
  • 871 Answers
There is one way to try in order to check if your speakers are working for those gaming sites. try to uninstall and re-install the audio driver for your computer.
Posted on Mar 16, 2008
SOURCE:
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
ALTEC LANSING ADA745 WILL NOT POWER UP
check whether the adapter is fine or not..
that may also be a problem...
Mar 26, 2008 | Audio Players & Recorders
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
How do you set up altec lansing speakers on a windows vista computer
If they have regular speaker jacks (1/8th inch) it should be a breeze. Just plug them to the corresponding audio jack, depending if you have a stereo or surround sound setup it may be one cable or a few, and vista should use your existing sound drivers and output the audio to the speakers. Otherwise you can adjust your speaker settings in control panel, which you shouldnt need to. Hope it helps. It can get tricky, let me know if it doesnt work out.
Apr 28, 2010 | Altec Lansing VS4121 Computer Speakers
Speakers r not playing
what driver are you using?
try to upgrade your driver to a vista driver (if none available for win7 yet) from your pc manufacturer website (if computer is a known brand computer) or from the audio card manufacturer website
Apr 24, 2010 | Altec Lansing 120i Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
I have a set of 4 Altec Lansing surround sound speakers with a subwoofer i bought in 2003 with my dell computer. I can't get any sound from them. Do you have any suggestions? I tried hooking the system up...
If you are listening through headphones that are plugged in to the Altec system, then your problem is the amplifier is bad. Can't help you online with that. Sorry!
Feb 24, 2010 | Altec Lansing Multimedia Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Vista messed up speakers
hi Avsandrick
Happy Holidays!
Doing a driver search don't help much, so I recommend 2 things here, wait until MS, make a Service Pack Cd, for Vista, or go to the Altec Lansing Page and see if for your particular model, there are drivers for vista.
other than that, a generic sound driver, could fix the problem.
Dec 29, 2007 | Altec Lansing ACS 54 Computer Speakers
138 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
