Question about Whirlpool LHW0050PQ Front Load Washer
Which is the fabric dispensor
Lost my manual, I want to use fabric softner. Which is the right compartment. As I am having dificulty, the one I tried just stays in the compartment.
Thanks
    President:
  • 1,294 Answers
Click on your model number (below FIXYA) on this website & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you hv your manual on line. If available, that is. It is usually the compartment with a tiny additional window, for water to dissolve & send the softener into the tub.
Posted on Mar 16, 2008
WHY DOESN'T FABRIC SOFTNER DISPENSOR NOT EMPTY ON MAYTAG NEPTUNE FRONT LOADER ?
there is three switched valves for cold and one for hot
the three cold are prewash main wash and softener
at the back of the valves back of the machine
there is a little cage inside the valve header
check its not full of dirt
you can remove them for cleaning with a pair of flat nose pliers
if this isnt the case replace the switched valve related to the softener
compartment water intake
Aug 11, 2014 | Maytag Washing Machines
Bosch Logixx 8 Fabric conditioner not releasing into wash cycle
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Washing Machines
The frabic softner dispensor is not releasing the softner in the washer.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 05, 2010 | GE WSXH208A Front Load Washer
There are 3 compartments . . .
It says the 1st compartment going left to right laundry detergant and stain remover, the middle is for the soaking agent, and the last one is for fabric softner. I hope that helps!
You can download the manual online and I found the info on page 12 of the manual.
Mar 02, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine
hi if your softner dispensor is a removable compartment from the soap powder drawer ? then remove the dispensor and you will see the pipe with cap on top at rear ? pull this pipe off and ensure it is not blocked and that the cap is a firm fit on top? then ensure the short pipe that is part of dispensor tub is clear reassemble and refit try again ? these softner dispensor work by syphon effect IE when you top up to recommended level with softner in dispensor ? it remains untill wash is at softner rinse cycle then when water is entered into dispensor of softner and the level is raised to above the short pipe within compartment and the outer pipe with top on ? the syphon effect takes place and the softner+waterlevel is is syphoned int machine and dispensor is empty?? i hope you understand ? it is simple and works if you think of a toilet cistern how it syphons water for flush it is the same principle hope this helps
Oct 30, 2008 | LG Washing Machines
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
My Axxis wfr 2460 is not releasing the fabric softner from the drawer
You could try a tooth-brush. And after you fill your quantity of softener, top it with water till the exit level of the compartment. You could also check whether water actually pours into the compartment during the final rinsing of the clothes; in this case you should check the inlet pipe screens of your inlet pipe into the machine; which can be done without opening up the machine.
Nov 30, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
42 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
