NEED A POWER LEAD
Hi dont know where to buy a power lead for a medion pockect pc no mdppc250
cheers
  • 95 Answers
Your best bet is ebay.
Posted on Mar 16, 2008
SOURCE:
Medion okoya p6613 makes 2shor beeb anthen a long continius beeb and nothing else happens
The most probable cause is the VIDEO CARD.
1. Power the computer down and disconnect the power lead
2. Check if the video card is seated well in the slot.
Best thing is to remove the card and put it back in the slot.
3. Check if the power-connectors (if any) are well connected.
4. Reconnect the power lead and power the computer on.
5. Check and if this did not help, replace the videocard.
Oct 16, 2011 | Computers & Internet
AUDIO LEADS
There should be one audio cable, Green.
goes into one of the green plugs behind the computer.
Oct 31, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Hi, my samsung laptop has an intermittent charging problem i really need help with please. i changed the inside jack lead because there was a break in the wire, the new jack lead gives me power all...
this is a common problem with laptops as you are using a new ac adapter helps a great deal the problem lies in the dc jack on the mother board not an easy task it needs replacing
Mar 15, 2011 | Computers & Internet
Hi I need a power cable as we have lost ours. Any idea where to buy one from Cheers Graham
Your power cable is pretty easy to get hold of. It's a standard "figure 8" type mains lead. I'm from the UK and can get them from Maplin Electronics store (high street shop). If you're in the USE, somewhere like Radioshack or simular should stock them also. You can also get them on ebay. cost around £2.00 or so. Again the lead connection ype is called a "figure 8". why? well turn 8 on it's side and it looks like the connection :-)
Jan 07, 2011 | Panasonic SC-HT520 System
When i connect it dont show it and it keeps saying about the usbnot being a 2.0
Ok you need a usb lead that has two inputs, your laptop/pc clearly only has usb standard 1.0 which doesnt give as much power out, so you need the lead with two ports on it and it will use one for power one for data.
I've linked a pic of one below in case you already have this lead or if you need to buy it. I certainly wouldnt pay £8.20 though! If it comes to it we can post you one for a lot less than that!
http://www.amazon.co.uk/LINDY-USB-Cable-Dual-Power/dp/B000FKP7XA
Oct 31, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Wii console isnt turning on and the lights are off. Whats wrong with it?
Hi, the problem could be with the power lead so give another lead a try if you have a mate who has got one ask them to bring their power lead round to try, if it works you need new lead if it dont then this would suggest that the power part of the board has over heated and fried a chip if this is the case you will need to send it off so check if you have any warranty left or not
make sure you dont do the following
play it whilst its on carpet
play it whilst its on top of another device such as dvd or sky box
doing the above will cause it to over heat and will lead to expensive repair bill.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 15, 2010 | Nintendo Wii Console
Medion mim 2120 laptop
Hi
First i reccomend checking the power cable and seeing if there are no short circuits or breaks in the circuit. - to do this unscrew the end of the power cable - this part wares out often and costs about 50 cents to replace.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Medion md40298 Notebook
British power lead for American laptop
Hi and thanks for replying. Basically any 'figure of eight' lead will do the trick, but I can dig one out for you if you would like?
Feb 18, 2009 | Dell Inspiron 1525 Notebook
POWER SUPPLY
bad abttery buy new one 1st even tho says charge dont have eneghf power in it to suport it all ok buy new try that 1st
Jan 28, 2008 | Packard Bell Easy One Silver 2101 Notebook
Sentrek car amplifier
The remote turn-on wire for an amplifier connects to a switched power source. If the head unit has a power antenna lead, or amp control lead, use it. If not, the remote lead can go to a power source that is switched with the ignition key. No matter the source, you need to fuse the wire with a 1 amp fuse at the point where you connect to the power source.
Oct 22, 2007 | Car Audio & Video
Open Questions:
Computers & Internet Logo
37 people viewed this question
Ekse
Alun Cox
