Question about Maytag Neptune MAH5500B Front Load Washer
I need to open the top so i can clean the screens going in to the washer
  • Anonymous Mar 23, 2014
    need to open the top of the maytag neptunhow do you do thise
    President:
  • Maytag Master
  • 2,651 Answers
The only screens you can clean are located in the throat of the water inlet valve which can be acess from removing the water hoses, dont know where or what screens you could possibly get to be lifting hte top
Posted on Mar 16, 2008
Neptune error code LR, means what?
Maytag & whirlpool was recall Maytag Neptune MAH5500B.
Oct 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Acquire screens for maytag MAH5500BWW
how to clean filter on maytag neptune front load washer
Dec 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer top load the washer stays in wash cycle and will not go to next cycle.
Clean out the pump. Ours was doing that as well, when our mechanic looked at it he could find nothing wrong with it so he looked at the pump and it was full of mud and junk. He said once it is cleaned out you have to run it twice a month empty to keep it clean. Ours has worked great since.
Apr 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Removed both water pump hoses, No blockages drum still has water init. Is this normal? Won't drain and go to final spin. Pump clean and spins free. Maytag Neptune MAH5500B
Water pressure switch adjustment or clogged. Check the small connecting hose to the switch body.
Final spin command signal generates from this part only.
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
