When you turn on the power button for the receiver it stays on only about 5 seconds and then it will shut off and there is a mute light that will flash
    Scholar:
  • 105 Answers
This is probably a protection circuit operating because the power output device to the speakers in the receiver is faulty.
Posted on Mar 16, 2008
SOURCE:
Can't turn my a/c off Or fan. I hit theoff button & just changes settings. Other than turn the car off itself, I can't figure it out. Earlier in the year rebooting the car'd work. No more.
Laptop not shutting completely (Power light and fan stays on ...
www.tomsguide.com/.../laptop-shutting-completely-power-light-fan-stay...
3 days ago - I have to hold the power button for 5 seconds for my laptop to turn offcompletely. ... I tried removing my battery completely, and started the windows with my A/C adapter and then shut it down ... when i shutdown my pc , my pc has get shutdown but the power light in my cpu tower ... Can't find your answer ?
Nov 19, 2015 | Computers & Internet
KTC-H2A1 satellite receiver has lost its audio output
Hi
Check the settings on your unit maybve you are in mute mode.
Thanks
Likha
Oct 01, 2008 | Kenwood Audio Players & Recorders
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
When i power on the device, it comes on but goes off about 5 seconds later.
Hi...
1st thing to check is for GOOD speaker connections at both ends
and not mixing A and B speaker wiring.
A Denon is usually a good brand. Might be worth servicing if need be.
Sep 20, 2008 | Denon AVR-1905 Receiver
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Akg sr 60
help me please akg sr60 , when torn on just mute
Dec 05, 2007 | Lands Phones
271 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
